Toshiba 27AF43 27" TV
Problem for Toshiba 27AF43 27" TV
Will not power on
By reginaldhodg on Sep 27, 2009
will not power on
Solution #1
posted on Sep 27, 2009
Not Rated)
johnnydiode
Rank: Guru  Toshiba Televisions & Videos  Expert
Rating: 94%, 198 votes
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 27AF43 27" TV
Questions and Unsolved Problems for Toshiba 27AF43 27" TV
Do you recommend Toshiba 27AF43 27" TV?
Answer
Answer
Toshiba model 27AF43 flat screen tv displays fine white lines across top five inches of screen.
Answer
Horizontal line at top. They are around 8 line space by .25 inch. Some station will emit signal in... (More)
Answer
i just got a toshiba tv...27af43..27". but i do not have the remote.pl help me as to how can i... (More)
Answer
What causes the picture to shrink and have black lines on each side,and the picture to be Jumpy ? Is... (More)
Answer
We have a toshiba 27af43 & when you turn it to AV to watch a dvd or play PS2 it displays the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 27AF43 27" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
