Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Can not get sky + hd hand control to set volume on to tv not comunicating
  • 325 Answers
Pleae follow the steps below. I hope it is a SONY like the picture indicates:
On the sky remote press the following buttons in this order.
TV
RED + SELECT ( hold these down until it flashes twice)
TV
0000
SELECT.
Job done. Please Leave a thumbs up when you get around to following these steps.
Thanks
Little Dish Fitter
Posted on Sep 28, 2009
NEED SKY CODE FOR AKURA APL3221W-HDID
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed see:New Remote Control Prices . To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state 'Sky rev' (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
Apr 09, 2011 | Televison & Video
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Codes are 0065, or 0405,or 0037
Code are 0065, or 0405, or 0037
Code are 1293, or 1206, or 0206
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
What code do I use to set up my sky hd remote to control my panasonic tx-p42x10b tv
With you sky remote follow the steps below:
TV
RED + SELECT ( flashes twice )
TV
0051
now try the volume button. If this works then press SELECT to save. If not press TV and then volume again. Repeat this step until the volume works then dont forget to press the SELECT button to store the code.
Job Done. Please leave a thumbs
Cheers
Little Dish Fitter
Oct 06, 2009 | Panasonic Televison & Video
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
Sky remote control tv code
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Apr 11, 2009 | Samsung PS42E7HD 42 in. HD-Ready Plasma...
Volume not working on sky remote
You will need a code in order for the tv functions of you sky remote e.g volume to work.
Click here to find out what remote control version you have.
If you have a remote control was produced after 2002 or there is no sticker
click here to use Sky's code look up tool.
Most SKY+HD Remotes are produced after 2002
Mar 21, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Cannot find code to program sky remote control
TV
TV
0156
cheers
Little Dish Fitter
Mar 12, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Logik L22LID18 22" hd ready digital lcd tv with ipod dock 7 dvd
Logik TV Sky codes; 1065 0908 1245 0726 0399 0039 0221.
Dec 08, 2008 | Directed 434MHZ Remote Control
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
271 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
