Question about Maytag Neptune MAH6700A Front Load Washer
Walks out of its space during med to high spin cycle
    President:
  • 1,489 Answers
This is probably either the motor mount at the bottom of the machine has come loose or the "shocks" are disconnected or worn out.
The front of the machine will have to be removed to inspect.
Please, let me know what you find.
Charlie
Posted on Sep 27, 2009
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Why is it that i only have a low and med final spin and not a high speed final spin after replacing the motor and thr shift clutch?
somthing to do with motor pick up coil allignment
the coil on the back needs it position set as per the service manual allignment check the clutch is fully engaged
also check brake isnt on a bit
etc
orrrr a contact on the motor connection plug is a bit burned...
Dec 08, 2014 | Speed Washing Machines
Maytag performa walks all over the floor during the spin cycle what to do?
Make sure the feet are level and that the plastic caps on the feet are in place. Sometimes they are left off during installation.
May 02, 2010 | Maytag Performa PAV2200
Walks during spin cycle
Is this a brand new machine?
If it is then the answer is simply that you have not removed the transportation bolts/brackets that secure the drum in transit. Look at the manual - it will tell you how to do this.
If it's not a new machine then post here again and i will try to help further.
Mar 19, 2010 | Maytag Washing Machines
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Mar 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
LG1812CW Walks During Spin Cycle
The rear 2 legs are fixed. The front 2 are adjustable. There are lock nuts to prevent the adjustment from coming loose. The front legs are to be adjusted to the minimum. While not running if the machine rocks, continue the adjustment. For few clothes there is a half load switch; best the read the manual well before anything. Well if the walking continues, check the rear for any shocks or springs that may hv fallen off during transport. Plug off the wall socket first.
May 28, 2007 | LG WM1812C Front Load Washer
Maytag Neptune MAH6700A Front Load Washer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
