Question about Fujitsu Siemens LifeBook T4210 Notebook
My T4210 tends to get very hot, about 50 degrees Celsius, but I know the fan can work harder and reduce the heat, because it does so from time to time. My question is: Can you manually make the fan work harder, effectively cooling the computer at all time?
  • 177 Answers
Download a program called SpeedFan, which will allow you to adjust fan speed (it's free, too!)
http://www.filehippo.com/download_speedfan/
Posted on Sep 27, 2009
1994 Toyota Corolla... Overheating! HELP! Replaced: radiator, water pump, relay, temperature sensor & thermostat! Fans are working! Even ran it w/out thermostat in, NP. What am I missing?
You have not mentioned 2 important things. 1, have you checked for leaking head gasket'? It can blow in any of 3 ways. a) between cylinders, which will result in a misfire, sometimes slight. b) between compression chamber and water jacket, which will cause a gassy smell in the cooling system. Open the radiator cap and start the engine, check for water bubbles when the engine reaches operating temp, and smell the water. 3) between water jacket and oil channels - there will be water in the oil. Check the dipstick for emulsified oil in the sump (a greyish colour).
And then 2 - engine timing. If the timing is fast, the engine will tend to run hot, especially when under load as in uphills etc.You will also hear pinging (spontaneous combustion). If the timing is slow, it will also tend to run hot when under load under certain circumstances.
Let us know more.
Apr 01, 2015 | 1994 Toyota Corolla
My aeg lavamat 41070 washing machine doesn`t work at high temperature ( more then 50 degrees) . At low temps it is working OK/
In the case of insufficient heating appears error code E60 what means replace the NTC sensor. Exclude heater, PCB or relay malfunction because you indicate that the machine is heated to 50 degrees Celsius.
Dado
Feb 28, 2015 | AEG Washing Machines
Electrolux ewx14440w washer dryer will not heat water
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
Oct 28, 2012 | Electrolux EW1000i Front Load Washer
Hi Expert, My Dell N5010 6monhs old laptop is getting really hot on the touchpad i mean really hot near 60 degrees (Using Speedfan) I am using targus chillmat and the overall temp is cut...
Did your ever notice is the blower the CPU is working. If not work so that's the cause of the heat. If the fan work use external fan that to use under the unit, you can buy it and your computer shop. If your using for longer hours heat will produce on the upper portion of the laptop mean i transfer. It is normal as long as the laptop OS doesn't hang. If its hang that's the big problem. Advice: use external blower to cold down the unit
Sep 11, 2011 | Computers & Internet
AS1830T-68U118, motherboard is very hot, 102 degrees celsius. sometimes, 50 ~ 90 degrees. What I do ?
Use a canned air to blow out the dust that might be accumulated on the system fan as it is one cause of overheating. Make sure that the fan it working properly as it should. Also avoid using your laptop in areas where the temperature is high.
Replace the fan if it is failing before it gets worse.
Hope this helps.
Jun 20, 2011 | Acer Aspire TimelineX AS1830T68U118...
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Does the temperature on the capacitors matter because my old ones had 105 degress celsius and the new ones i bought have up to 85 degrees celsius
No,not a problems,if it only 10 or 20 degree of celsius.Ur tv is not in an incloser like a cabinate,right?Because it harder for the heat to disapper,if tv it in a small incloser cabinate.
Oct 11, 2010 | ASUS Televison & Video
Heat- Is parking a car in high sun temperatures
heat is not fun during any time, is it harmful, yes and no. it can cause your Ac to work harder to cool the vehicle down in addition to eventually fading your interior. a suggestion to the heat would be to have light or white paint for the exterior (probably to late for you on this) and some type of window tint to reduce the heat on the interior. my vehicle hits about 110-120 degrees interior temp during the summer month's. 4 hours a day is not to bad for the sun exposure. I hope this helps!
Sep 24, 2009 | 2003 Kia Rio
Temperature problem
Make sure you have 50/50 mix antifreeze, it will still run hot if you have 100% antifreeze. As the antifreeze get's hot, it turns in to gel and the flow slows down and the heat exchange will be reduced. Water is great in transferring heat but it will boil over so antifreeze is added to keep it from boiling over, so a 50/50 (water/antifreeze) mix is used. You can go a bit higher with the antifreeze but try not too and in the winter you can go 40/60 (water/antifreeze) if your in really cold climate area. The other thing to is do you have electric radiator fans?? Think you do, make sure it's working. When you turn on your A/C the radiator fan should come one and also when the temperature  gauge hits 180 - 195 degrees the fan should come on too. If not check the fuse, relay's and wire harness to the fan. Good luck and hope this helps.
Jun 23, 2009 | 1992 Chevrolet Caprice
Problem of frequently shutdown unexpectedly for m6810 laptop ........When fan starts after some temp. goes up to 53 C. it causes....
laptops/notebooks tend to overheat more quickly the desktop resulting in shut down, try a laptop/notebook cooling fan
Feb 27, 2009 | E-Machines M6810 Notebook
Fujitsu Siemens LifeBook T4210 Notebook Logo
406 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
