Question about Sony Ericsson W760i Cellular Phone
Lost manual and the bluetooth code for pairing to handsfree
Bought a supertooth buddy to for use with my htc legend but it will not connect
Thanks for using Supertooth.
do the pairing as explained below:
Your Supertooth BUDDY must be in pairing mode before searching from the
phone.
1. From OFF, press and hold the On/Off button for 10 secondes until the
Bluetooth Indicator turns blinking red/blue. The handsfree kit is now in
pairing mode.
2. While the handsfree kit is in pairing mode, access the Bluetooth menu
of your phone. Turn on the Bluetooth function and execute a Bluetooth
search. (See your phone's manual.)
3. When the phone displays the list of Bluetooth devices, select ST
BUDDY.
4. If the phone asks for the password/pin code, enter 0000 and press Ok.
5. The handsfree kit is now ready to use.
Best regards.
SUPERTOOTH
Sep 25, 2011 | HTC Cell Phones
Seal handsfree not pairing
with the phone's bluetooth active
press button to turn the seal device
press blue button on seal device
on phone, select pair new device
when the seal device is found, use code 0000 to pair the phone to the device..
next time you connect, turn on the phones bluetooth and the seal device. press blue button on seal device. it should automatically pair.
Sep 15, 2009 | Handspring Visor Prism Handheld
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
Pama bluetooth manual
pama omega bluetooth handsfree kit pairing code
Jun 30, 2009 | Handspring Visor Prism Handheld
Can't pair nexus text to speech with my I phone don't have instructions either can anyone help??
Press and hold the 'Call' button on the Nexxus handsfree for 5 seconds. It will then go into Pairing mode. Set your phone handset to search for Bluetooth devices.
Pass-code = 1234
Good luck.
Andrew
Apr 29, 2009 | Cell Phones
Pairing a Bluetooth handsfree kit
Instruction manual is available at:
http://www.pama.com/product_images/mediabank/documents/EPSILON_instructions.pdf
Mar 15, 2009 | Lands Phones
N73 not pairing with visorlite
here's the manufacturer's website where you can download the manual (it is also marketed as Supertooth Light)
http://www.supertooth.net/down_light.html
Mar 13, 2008 | Nokia 6300 Cellular Phone
Accept code for a bluetooth headset
If this solution doesn't work hold down both the volume up and down buttons on the head set for about 5 seconds whilst searching for a new paired device with your phone then when asked enter the code 0000 and connect
Sep 17, 2007 | Nokia 6300 Cellular Phone
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Sony Ericsson W760i Cellular Phone Logo
32 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
