I had adobe 8.0 and could edit and save adobe. wont save with 9.0
I had adobe 8.0 and could edit and save adobe files where i filled in data fields on forms. I downloaded version 9.0 and notes said I could no longer safe the information entered on form. Must I now download 8.0 again in order to safe data on forms ?
  • 44 Answers
Unfortunely yes, they put extra security on the latests version that make it quite hard to do any thing at all
Posted on Sep 27, 2009
Missing CD DVD driver
The issue could be due to missing or corrupt CD/DVD drive drivers. If you are using Windows XP OS, then go ahead and peform the following steps:
=== Backing Up Registry and Registry Key ===
CAUTION: The registry contains critical information and a
registry backup is essential. An incorrect registry
entry may cause serious system problems or prevent the
computer from starting. You will not be warned of any
incorrect registry entries. If the registry is not
backed up, the only way to recover the system is to
reinstall the operating system. Do not double-click the
Backup.reg file on the desktop unless you intend to undo
the changes you are making to the registry.
1. Click Start and select Run.
2. Type Regedit in the Open field and click OK.
3. Click "File" in the menu.
4. Click "Export" from the drop-down menu.
5. Click the down arrow beside "Save In" and select Local Disk(C:).
6. Type Backup.reg in the File Name field.
7. Click Save.
=== Deleting UpperFilter and LowerFilter Registry Keys ===
1. Click Start and click Run.
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor and restart the computer.
May 24, 2010 | HP Compaq nx7300 Notebook
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
Mar 16, 2010 | HP Computers & Internet
I AM TRYING TO FILL IN AN APPLICATION FORM IN A PDF FILE AND I DON'T GET ANY OPTIONS TO HIGHLIGHT TEXTS. IS IT BECAUSE THE COMPUTER I'M USING DOESN'T HAVE MICROSOFT WORD INSTALLED?
What program did you use to open the PDF? If you opened it with the default program, you probably used Adobe Reader which does not allow you to edit PDFs. You can import PDFs into several Office suites with add-ons. For example, Open Office 3 has a PDF add-on that lets the PDF be opened and modified in Draw and Impress. There are also online PDF editors and some low cost alternatives to Adobe Acrobat is the full program that makes PDFs. PDFill PDF Editor gets some good reviews
http://download.cnet.com/PDFill-PDF-Editor/3000-6675_4-10295757.html
as does www.pdfescape.com/ (an on-line option). Please note that most will put their logo on your document as a footer or somewhere unless you use a paid version.
I hope this helps.
(word does the PDF import more easily as I recall (possibly with an add-on) but there are alternatives.)
Feb 19, 2010 | Microsoft Windows Vista Home Premium...
How do i get my gprs working
AT&T:
Main Menu
* Entertainment
* Services
* Data Account
* GPRS
- Find one free account (like Account 8, etc)
* Edit
- Change 'Account Name' and put the value 'ATT MMS'
- In 'apn' field put the value APN (which is wap.cingular)
- Fill the fields username and password with the ones on the table USER and PASSWORD (you don't actually need a user name and password for AT&T, you can leave these blank)
-Click 'Done' and say Yes to Save.
* Main Menu
* PIM
* Messages
* MMS
* Message Settings
* Server Profile
- Find one free account (like Profile 8, etc)
* Edit Profile
- Rename Profile and put the value 'ATT MMS'
- In Homepage field put the value HOMEPAGE (which is http://mmsc.cingular.com)
- In 'Data Account' select GPRS and then the account created before (the MMS one).
- Select 'Connection Type', choose HTTP and click OK
- Fill in the fields Proxy Address with PROXY and Proxy Port with PORT. Then click OK (066.209.011.061 is the proxy and 9201 is the port number)
- Fill the fields username and password with the ones on the table USER and PASSWORD (don't need a user name and password)
* Go back and Activate Profile
Nov 16, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Unable to import text file to access table
Hey everyone, I was able to fix my problem using the following:
filnam = Me![Text2]
Set objFile = CreateObject("Scripting.FileSystemObject")
Set objText = objFile.OpenTextFile(filnam)
Set rs = CurrentDb.OpenRecordset("FlatFileImport")
once = False
If Not IsNull(Me.Text2) Then filnam = Me.Text2
Open filnam For Binary As #1
Do While Not objText.AtEndOfStream
strTextLine = objText.Readline
Data = Split(strTextLine, ",")
If once Then
rs.AddNew
rs.Fields(1) = Data(0) 'Site ID
rs.Fields(2) = Data(1) 'Client ID
rs.Fields(3) = Data(2) 'Client Name
rs.Fields(4) = Data(3) 'DDA Account
rs.Fields(5) = Data(4) 'Process Date
rs.Fields(6) = Data(5) 'Good Checks Singles
rs.Fields(7) = Data(6) 'Good Checks Stubs
rs.Fields(8) = Data(7) 'Good Checks Partial
rs.Fields(9) = Data(8) 'Good Stubs Partial
rs.Fields(10) = Data(9) 'Good Checks Multi
rs.Fields(11) = Data(10) 'Good Stubs Multi
rs.Fields(12) = Data(11) 'Check Only Checks
rs.Fields(13) = Data(12) 'Check Only Stubs
rs.Fields(14) = Data(13) 'Check And List Stubs
rs.Fields(15) = Data(14) 'Check And List Checks
rs.Fields(16) = Data(15) 'Suspense Checks
rs.Fields(17) = Data(16) 'Suspense Stubs
rs.Fields(18) = Data(17) 'Correspondence
rs.Fields(19) = Data(18) 'Envelopes
rs.Fields(20) = Data(19) 'Express Mail
rs.Fields(21) = Data(20) 'Lookup Stubs
rs.Fields(22) = Data(21) 'Online Lookups
rs.Fields(23) = Data(22) 'Stubs Only
rs.Fields(24) = Data(23) 'StopFile Hits
rs.Fields(25) = Data(24) 'SLC
rs.Fields(26) = Data(25) 'SL2
rs.Fields(27) = Data(26) 'MICR Scanline
rs.Fields(28) = Data(27) 'KeyStrokes Correspondence
rs.Fields(29) = Data(28) 'Keystrokes SLC
rs.Fields(30) = Data(29) 'Keystrokes SL2
rs.Fields(39) = Data(38) 'Exception Queue
rs.Fields(40) = Data(39) 'COA Queue
'IMAGE ARCHIVE ITEMS
rs.Fields(41) = Data(40) 'Image Archive Reports
rs.Fields(42) = Data(41) 'Image Archive Storage
'BATCHES PROCESSED
rs.Fields(43) = Data(42) 'Batches Processed
'ARC ITEMS
rs.Fields(44) = Data(43) 'Low Speed ARC Attempts
rs.Fields(45) = Data(44) 'High Speed ARC Attempts
rs.Fields(46) = Data(45) 'Low Speed ARC Converted
rs.Fields(47) = Data(46) 'High Speed ARC Converted
'ICL ITEMS
rs.Fields(48) = Data(47) 'ICL Attempts
rs.Fields(49) = Data(48) 'ICL Converted
rs.Fields(50) = Data(49) 'ICL Non-Conforming images
'RETURN ITEMS
rs.Fields(51) = Data(50) 'Auto Returns
rs.Fields(52) = Data(51) 'Returned Items
'POSITIVE POST (CDM) ITEMS
rs.Fields(53) = Data(52) 'Positive Post Checks
rs.Fields(54) = Data(53) 'Positive Post Stubs
'REMOTE PAYMENT CAPTURE ITEMS
rs.Fields(55) = Data(54) 'Remote Payment Single Checks
rs.Fields(56) = Data(55) 'Remote Payment Single Stubs
rs.Fields(57) = Data(56) 'Remote Payment Multi Checks
rs.Fields(58) = Data(57) 'Remote Payment Multi Stubs
rs.Fields(59) = Data(58) 'Remote Payment Check Only Checks
rs.Fields(60) = Data(59) 'Remote Payment Check Only Stubs
rs.Fields(61) = Data(60) 'Remote Payment Check & List Checks
rs.Fields(62) = Data(61) 'Remote Payment Check & List Stubs
'DOLLAR DEPOSTIED & PP CORRO REJECT ITEMS
rs.Fields(71) = Data(70) 'Dollars Deposited
rs.Fields(72) = Data(71) 'PP Corro Rejects
rs.Update
End If
once = True
MyLine = ""
MyLine = MyLine & ch
MyLocation = Loc(1)
Loop
MsgBox " File has been successfully imported! "
Close #1 ' Close file.
rs.Close
'close and erase the file from memory
objText.Close
Set objText = Nothing
Set rs = Nothing
Sep 08, 2009 | Microsoft Access 2003 for PC
Adobe Acrobat 7.1
Usually if this message appears that means you have a problem with the link from adobe to word, because the virtual printer installed by adobe has to work in order for you to save the documents you edit.Some of these messages don't have a real meaning and they are just a message bug, but if you can't save the documents you edit then you need to reinstall the adobe acrobat.
Oct 27, 2008 | Adobe Acrobat 7.0 for PC
Editable forms with Adobe reader?
With adobe profesional you can make a PDF form, and send to the recipients. They can fill the form with Adobe reader and send it to you back, but only the data will be sent to you, not all with the pdf.
You can collect the data with your adobe profesional. Your programmer of medical paperless system can make the program to put that data in your database.
Here is the simple procedure:
1. Create form: Open adobe prof, menu advance --> Form --> create new form. You will go to Adobe design to create the form, there you can also retrieve your scanned document.
Don't forget to put "submit button" and your email address.
2. Then save as pdf form. It is ready to be send to your recipients.
3. The recipients will fill the data and send to you by pushing the "submit button".
4. You will receive the data in your mailbox, as an attachment of email. You can use adobe prof to collect it, example to put it in Microsoft Excel.
Go to menu advance --> form --> Create Spreadsheet from data files. A dialog box will come out, put in the files you received from your recipients. then go on, you will have the Excel data.
For put it in your database of your system, your programmer should create a program/ included in your system's program.
For Guest, to fill up is easy, just open the pdf form with Adobe REader, fill it and click the submit button.
Apr 15, 2008 | Adobe Acrobat Professional 7.0 for PC
Adobe reader forms problem
it might be jpeg or bitmap instead of font or value. so it wont change.
Feb 17, 2008 | Adobe Acrobat 7.0 for PC
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
