Question about EverFocus Televison & Video
Everfocus DVR EDSR900.I need to send it to a
I have a Everfocus DVR EDSR900 which is switching on however does not power up/ colour barcode continues.I need to send it to a service centre in Mumbai, India.
Is there an authorised Everfocus service centre where i can have it sent.
  • 8404 Answers
SOURCE: i want to know authorised acer service center in
Go to the Acer site for your country ... thre is a service center locator to be found at the site.
Thanks.
Posted on Aug 06, 2010
SOURCE: i need to know of a service centre in mumbai,
i have a kodak m1033 digital camera.yesterday while taking snaps heavy rain came. though i shutted the camera within two mnutes ,and taken further snaps after 15 minutes when the rain was over, but after two and a half hours from i am not been able to open the camera or charge the camera with the help of the charger. please help
Posted on Aug 10, 2010
SOURCE: service centre in Mumbai India
Service center for Gaggia, Lapavoni in Mumbai<br />ID gourmet India Pvt Ltd.<br />Appasaheb marathe marg,autohanger,prabhadevi,mumbai-400025<br /><br />contact:- Shrikant Shinde<br />Service Engineer<br /> 91-9594980001<br />
Posted on Aug 24, 2010
SOURCE: Samsung mobile Authorised service centre
which address in mumbai boriwali area of service center. kindly give the address as soon as possible
Posted on Jan 19, 2011
adamncc1701
  • 158 Answers
SOURCE: I have a Harmon Cardon AVR25II amplifier. I am
Hello im unsure of a harman servicer in your area but i do know there is not going to be a bose authorized as they have cancelled all outside service and request the customer to ship it to there factory.
Posted on Feb 21, 2011
Cannot download video from dvr
DVR is meant to be used as playback device it's recorded information is stored in an encrypted form in the device. Even if the data is retrieved it might not be playable in another device.
Apr 18, 2014 | EverFocus ECOR264-9X1-1T - ECOR264x1...
Cannot remember password need to rest it on ECOR264-4D2
On some DVR's you can reset the password by downloading .bin files from the manufactures website onto a thumb drive. I've done it for other models just not Everfocus. It's pretty simple if you can get access to those files. After you have them on the thumb drive you power down the device, plug in the thumb drive, the device scans the thumb drive and resets your password back to default, hope that helps!
Dec 21, 2013 | EverFocus ECOR264-D2 ECOR264-8D2 8 Channel...
I want to find a good app to open copied video from everfocus home security cameras
You can use restore to take the computer back to a date that you know that it worked. You can use right click and open with to set the program, you can reinstall everfocus. You can manually set the file associations.
Dec 19, 2013 | EverFocus ECOR264-9X1/2T ECOR264 Series 9...
M Brand new DVR doesn't recognize its SATA hard disk? I have confirmed there is power on Hard disk. when it was not working. I format it by using windows 7 and reinstall it . what the reason?
is this the hard drive you recieved with the DVR? it is possible that the HDD is set up in the wrong format. windows sets up your HDD in a NTFS format which is compatible with most DVR's but i know there are some EverFocus units that read the HDD in a diffrent format. if this is the case you need too check in your owners manual in the HDD section, it should tell you what format it records onto, then place the HDD in your PC and reformat it to the right one.
Nov 03, 2013 | EverFocus EDVR16D1/500 16 Channel, 120...
Dvr password
default password is 11111111
Apr 26, 2013 | EverFocus ECOR264-4F1/500 H.264, 4...
I need a replacement remote control for Everfocus EDVR16D1-250 Digital Video Recorder DVR DVD can any one help
you can purchase a programable universal remote at most electronic stores, if your looking for a factory replacement I would check out this web site. I hope this helps.
http://www.geminicomputersinc.com/security-everfocus-electronics-corp-.html
Sep 25, 2009 | Televison & Video
Formatting disks for EDSR1600
The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
Do NOT set any drive to Slave!
Lock the drive trays; if you don't the DVR will not go into record.
Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
Aug 09, 2008 | EverFocus EDSR1600 16 CHANNEL 160GB...
Televison & Video Logo
159 people viewed this question
Top EverFocus Televison & Video Experts
Are you an EverFocus Televison and Video Expert? Answer questions, earn points and help others
