Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
How do i fit new brushes in dyson dc 07 have the
How do i fit new carbon brushes in dyson dc 07. I have the motor out
  • Anonymous Mar 31, 2014
    Motor sure on Dyson dc is not centered
  • 27 Answers
You have got to open the motor housing that isthe black casing that surounds the motor first then the motor comes out then you can see the brushes thay come out by lifting the copper strip up gently with a screwdriver then you pull it out then put in new ones
Posted on Oct 03, 2009
Testimonial: "Great thanks that's awesome"
Dyson DC 50 Serialno AH6-UK-EHA1562A. rEQUIRE NEW BLACK BRUSHES, D I NEED TO BUY A NEW ASSEMBLY OR CAN i BUY THE BRUSHES?
Hi there, it's Jack at Dyson.
DC50's brush bar comes as a complete assembly. The soft black anti-static carbon fibre filaments aren't available as individual components.
However if the carbon fibre filaments on your DC50's brush bar are worn or damaged in some way, we may be able to help. If you can email a clear picture of the issue to me directly at help@dyson.co.uk, I'll be in touch as soon as possible to provide further assistance. If you can also include your full home address and post code, as well as your contact phone number and the date on which you purchased your machine, that would be very helpful to us.
I'll look forward to hearing from you.
Feb 17, 2015 | Dyson Dc50 Ball Multi-Floor 2-Tier...
How do i fit new carbon brushers to dyson dc14
It will be a pointless exercise Ron. By the time the brushes on a YDK DC14 motor have gone, so has the armature. You need to replace the motor. You can get a new motor here: Dyson DC14 new motor.
Also, be sure you change the filters; one of which is washable.
Nov 12, 2010 | Dyson DC14 All floors Bagless Upright...
Hopw to fit new belt
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, if your brush bar isn't turning then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look atwww.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07.
Oct 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I want to oil the bearings in my dyson dc07 upright vacuum...but dont know where theyre located ..help
Hi there SmartAlec from NelsonVacuums.com.au here. Unfortunately this machine does not have bearings that you can oil. You can replace the bearings that are in each end of the brush roller by removing the brush, taking the end caps off and pulling out the bearing and putting new ones in (size 625 from memory). The bearing in the motor however is sealed and cannot be replaced. This model is designed to have a motor replaced if the bearing is failing. I dont know if this is terribly good news for you but it is accurate.
If you live in Australia you can get the bearings and motor from NelsonVacuums.com.au
May 08, 2010 | Dyson DC07 All Floors Bagless Upright...
Brush doesn't spin
This model has Brush Control
The Brushbar can be turned off to protect rugs and delicate floors
You've either accidently turned the brushbar off or the belts broken
Apr 08, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Replace dyson 07 animal brush roll assembley
The end caps of the brush assembly which contain the bearings are only a push fit onto the spindle (quite tight). Remove these and the brush bar will pass through the drive belt loop. To achieve this the belt has to be stretched slightly so care has to be taken not to over-stretch what might be a belt getting to the end of its life. When refitting the end caps do not forget to aline them properly so they fit into the sole plate recesses correctly.
I cannot see at the moment how to replace the drive belt on the DC 07 without significant dismantling (that will probably be my next job) I do not see the use of the Dyson tool you offered.
Oct 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
We have a dyson dc 07 animal the machine was working fine then switched off after returning to the machine minutes later it wouldnt switch on, i removed on off switch cover and used a short piece of wire...
It could be the motor. I'm having to replace the brushes on my DC 05. It appears that you can only get brushes for the YDK motors in the DYSON, not the Panasonic motor. Which might be saying something about the YDK motors. What happens is that the carbon brushes wear down which is normal. However, the contact wire from the brush to its connector is set so that when the brush wears down, the wire is short enough to stop the spring etc from damaging the commutator. The end result is that you get an intermittent operation of the motor before it finally dies.
I believe all the DYSONs come with the option of both motors and you cannot really tell which motor you have until you take the thing to bits. You also cannot change motors without changing various other parts on the hoover. On my DC 05 the writing on the YDK motor tells you which one it is.
This website www. tasweb.org ,select the DC 05 option and scroll down tells you how to take the thing to bits. A search on google etc for your DC 07 may give similar results. Best of luck!
Jun 20, 2009 | Dyson DC05 Cylinder Bagless Canister...
"CHANGING CARBON BRUSHES ON A DYSON VAC"
Solent Tools have a full range of Dyson brushes available. Tel 023 8057 8057. www.solenttools.co.uk
May 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
582 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
