Bosch WFMC 3200 Front Load Washer
Problem for Bosch WFMC 3200 Front Load Washer
Bosch Washer WFMC3200.
By voroni999 on Sep 27, 2009
My drum of the washer will not spin during cycle. If you turn it to a cycle and press start, it will fill, but the drum just sits there, then it will drain itself. Basically it will go through the motions of the cycle, except the drum never moves. It doesn't make any noise whatsoever, no hum from motor or anything, just silence.
Door will lock and unlock.
Took the rear cover off, belt is intact and all connections to and from motor are tight, nothing visibly wrong with it.
I have no error codes on display either.
I did spin test. When I put P:04 and pressed start - the door was locked, it start drain but the unit did not agitate and did not spin. There is an error code E20. What does it mean?
Solution #1
posted on Oct 20, 2009
Not Rated)
hattonhall
Rank: Wiz
Rating: 77%, 129 votes
Contact a Bosch technician. You may have to at least pay for a service call.
Was this helpful?
Yes
No
Popular Solutions for Bosch WFMC 3200 Front Load
Questions and Unsolved Problems for Bosch WFMC 3200 Front Load
Do you recommend Bosch WFMC 3200 Front Load Washer?
Answer
Answer
I have a Bosch WFMC3200 front loader. About a month ago the lights on the display started to dim. ... (More)
Answer
My 3200's door hinge broke Where can I get these parts?
Answer
I would like to replace the door seal boot as it is moldy and very gross. I have the outer edge... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , TX
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
