I have a Fridaire AC window unit about 3 mos old. It just would not work with the buttons, then we unplugged it to reset it, and now it will just beep when we plug it back up and push reset, then it turns off and will not come on at all. It looks like from the side the model number is: FAA087(5 or maybe a S )A ....I have called the number on it, and I get recordings and then to call a LONG distance number and no one to help. That was Thurs and we sure are hot!!! Can you help???
    President:
  • 1,922 Answers
How long do you leave it unplugged for? try a couple of hours to let any memory voltage dissipate and clear memory, then retry, also does it have any troubleshooting ideas in the owners manual, possibly a certain way of steps to un glitch unit and make operational again
Posted on Sep 27, 2009
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
My window ac was leaking water and ran down wall and got the plug wet. we have tried drying it out with hairdryer but when we plug it in the reset button keeps switching. do i need a new ac or can i buy a...
It's hard to know which one needs replacing, without testing the outlet first. Unplug the AC unit and outlet in a lamp or some other electrical appliance to see if the outlet works as it should. If does function correctly, then the problem is in the AC unit. But, buying a new power cord will probably not solve the problem. More than likely, one of the circuits or sensors in the control panel got fried, when the water got into the outlet and shorted it out. That's why the reset button n the cord won't reset.
Depending on the age of the uni, you may want to consider having it repaired, rather than replacing it. But, if it's 5 years old or older, I'd opt for replacement.
Now, lets address what caused the problem. Either the drain hole in the drip pan was clogged and or the rear of the AC unit did have enough downward tilt. The general rule of thumb is 1/4" to 1/2" rear downward tilt. This allows the water collected in the drip pan to flow to the rear of the unit and drain away thru the drain hole. Whether you repair or replace the unit, keep this in mind.
I hope I was able to help you and thanks for choosing FixYa.
Aug 22, 2011 | Heating & Cooling
Own a GE 29870GE1 telephone with digital answering machine. The digital part works but can't get a dial tone.
Try unplugging the phone from the wall power outlet plug it back after like 3 minutes. Power on and see if you get a dial tone, if not, try reset the unit, once the unit is reset, the problem should be fix. Follow this steps to reset the unit,
Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem.
Take care.
Sep 23, 2010 | GE 29897GE1 Corded Phone
LG AC compressor problem
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
Jun 28, 2009 | LG Heat cool Window Air Conditioner
Cannot engage RESET Button on plug to power the 220v AC unit
The reset button is a voltage leak detector it is possible the unit has a short in it or the cord has a short
Apr 28, 2009 | Heating & Cooling
Printer jams. gray foam released in paper path.
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Dec 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
How can I clear E1 permently from my AC
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Jul 30, 2008 | Sharp AF-S120FX Air Conditioner
Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
Jun 10, 2008 | Frigidaire FAC126P1 wall/window Air...
Got instruction to unregister KX-TG6074B
If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
1) On the base unit:
Press: FUNCTION or PROGRAM
Button name varies by phone model.
2) Press: MUTE
3) Enter the numbers 3, 3, 5, #
4) Enter the handset number (1 to 8)
Mar 14, 2008 | Panasonic KX-TG2740 Cordless Phone
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
