I have a problem with my Epson sx600fw all-in-one printer, it stopped printing black, the cartridge is new but i believe the head is blocked. I've used the in built head cleaning several times,but still no joy, anyone got any other idea's?...Tried getting in touch with Epson but no joy.
  • 3 Answers
You aren't the only one-it happened to mine AND the replacement and I've read quite a few other cases with this model.Epson however deny there is a fault.If it's within the first 6 months your retailer has to repair or replace it,you don't have to prove the fault.Read up on the Sale of Goods act and don't be fobbed off as some retailers will try to do.
Posted on Oct 22, 2009
New black ink cartridge won't print back
Hi if you change your cartridge for new one and you don't see it printing most likely your printer head is blocked to unblock it get something like that http://www.longforte.com/print-head-cleaning-solution or you can try pour hot water on a
Apr 14, 2014 | Epson Office Equipment & Supplies
BLACK INK NOT WORKING
Black ink head clogged/cartridge empty. Go to Printer Utility and do a Nozzle Check, Print a Pattern. If Black pattern lines are missing/broken then do another cleaning. Don't forget to try a new cartridge if the cleanings do not work. Refurbished Epson printers are great and can be purchased at www.epson.com/clearance. I have used them for 15 years.
Feb 15, 2013 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epson sx215 wont print pdf files
You need to clean the print heads first - if they are blocked they won't print.
Clean them several times - then try the print check.In Case You Still Having Problem Then Follow Us For On : Epson Printer Support
Sep 20, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
May 05, 2011 | Epson Stylus CX6000 All-In-One InkJet...
Epson SX600FW - this will not print black even-though the cartridge is genuine and full. It will print the document in any other colour than black
You might need a reset as the B&W cartidge has not been detected. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 06, 2011 | Epson Printer
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to clean inkjet of epson styles sx600fw?
Had same problem with my SX600FW. Changed all cartridges umpteen times because head cleaning process empties working cartridges. Ended up with none of the colour cartridges working! Paid Epson repairer £20 for them to tell me the print head was clogged and repair will cost as much as a new printer!! Problem started just after warranty expired!! I shan't be buying Epson again even though it was a great tool when it was working.
Tom
Apr 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
The black ink will not print on my Epson Stylus SX600FW printer. Th eprinter was left for a few weeks without black ink. Has the needle heads dried up and become clogged? How can I fix this problem?
I have an Epson sx600fw which has had a problem printing with black ink. I spent alot of money trying genuine and cheap inks as official advice is to replace with a genuine epson cartridge and clean up to 6 times before seeking further help. Tried this to no avail. By accident I found that if you set the paper type to glossy or photo then miraculously the black will work but in this setting it is slow. Epson replace the printer under warranty but I have just received a new one and it has exactly the same problem. I am slightly reluctant to buy another set of genuine inks to waste through 6 cleaning cycles as they are over £35 so am not sure what to do but I guess I will approach Epson again.
Sep 11, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer won't print black
In view of the original poster's lack of interest, I think we can call this one "Solved by Poster".
May 11, 2008 | Epson Stylus C62 InkJet Printer
458 people viewed this question
jasbo
jasbo
