Question about Sony DSR-25 Mini DV VCR
Jamed tape I couldn't get the tape outside because it was jammed.finally I took out the tape but the deck is steel not working. When you connect it to the power, the power light is green for few secconds and then turn back red
  • Anonymous May 19, 2008
    I placed a full size tape in - not a mini - and it didn't get stuck. The power shut off and when I unplug it, it powers up for a few seconds but not long enough for me to eject the tape before it shuts off again.
    Problem Solver:
  • 10 Answers
This happens often in my business. Sony DSR is the most delicate cassette compartment out there. It also sounds like the unit is in auto off mode(electronic proublems as well). Please for your sake take this unit to Sony or some one qualified to repair this. You should expect replacement of the compartment and what ever damage occured while removing the tape. Parts for these decks are not cheap, If you had taken it to a service person with the tape stuck inside the monitary damage would far less. The one good thing is this is a consumer unit, if it where a DSR 1500 two models up it would pro and they share parts price for repair x3 across the board.
Posted on Dec 18, 2007
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
My Philips MC145 tape deck doesn't work all of a sudden
I am guessing you took this apart? It sounds like the drive belt broke.
Feb 08, 2013 | Audio Players & Recorders
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
Wr565 - both decks jam the tape when i play them. any suggestions?
rss13506,
I'm not sure what you mean by jam but I bet you need to clean the head, roller and pin in each deck. Use rubbing alcohol and a q-tip to clean the:
1) Head (silver thing in the center bottom where the tape slides over; it produces the sound).
2) Roller (black wheel thing that keeps tension on the tape).
3) Pin (above the roller-works with the roller).
If any of these parts are dirty the deck will eat up the tapes. Clean them even if you do not see visible dirt on the q-tip as dust does not show as well as oils in the air typically from cooking will gum up the parts. Give them ample time to dry before trying a tape.
As any tape playing person knows from the 70's and 80's-try a tape you don't care about first, to make sure the deck will not eat up the ones you like!
-Chris
Sep 06, 2010 | Sony CASSETTE DECK Single Dual Cassette...
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Tape reel on either deck stops and tape gets jammed. This is on a Tascam dual cassette deck model 322.
Try replacing the belt, because when the belt is a bit old it looses its elasticity and it can't drive the whole thing properly.Tape A and Tape B works independently.
Jul 25, 2010 | Tascam 322 Advanced Dual Well Single...
Sony mp3 MHC-RG440s
well fuses are at the power supply sections and if the tape was jamed inside the deck, just disconnect the plug and try to take-off the case/cover of your unit but before opening it wait for about 1-2 hours to discharge the capasitors and then disassymble your unit try to get the tape deck and then get a knife a scissor, something to cut the tape inside the deck, thats the best solution, but you won't get your tape back though even when you get your tape uncut well, when you play it again you will not get good sound.
maybe your tape deck have a problems, maybe a broken gears, a belt was snaped, or a relay is the main problem.
its better to observe your unit first before you play a tape again.
ok? hope you could get your system back in good condition and have a good day.
Mar 16, 2008 | Sony MHC-GX450 CD Shelf System
Sony DSR-25 Mini DV VCR Logo
284 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
