Question about HTC Touch Cell Phone (Unlocked) - Soft Black
The battery life on my htc touch phone is so poor! I charge it fully till the whole bar is green and it literally lasts for all of one hour and that's supposing i make no call or use no programs, then its even shorter. Please,what do i do? Thanks in advance
  • 109 Answers
You have to replace the battery
Posted on Sep 27, 2009
Htc aria wont fully charge
I had the same problem with my droid 2 before i got rid of it for my iphone. I took it back to the store and they said," the battery is done with its life." lol. i got a new battery and it fully charged after that until i sold it. Also my friend had the same problem but his was his charger.
Hope this helps
May 30, 2012 | HTC Aria Cell Phone
Tip
HTC increase Desire battery life.
<span>Preparing...<br />With the phone in the on position.<br /><br />Fully charge the battery with the phone on... (until the led turns green.)<br /><br />Once the led turns green, unplug the charger until the led goes off. <br /><br />After the led goes off, plug the charger back in. When the led turns green , power off the phone.<br /><br />now.... with the phone fully powered off...<br /><br />1. Unplug the charger. <br /><br />2. Wait until led goes off. <br /><br />3. Plug charger back in until the led turns green. When it turns green, unplug the charger again and go to step 1.<br /><br />4. repeat steps 1 and 3, 10 times. This may take anywhere from 30 seconds to 30 mins per cycle. Typically only about 1 minute. though.<br /><br /><br />DO NOT DRAIN THE BATTERY. The goal is not to empty the battery and recharge like ni-cads (those have memory, these don't). These are lithiums, so we need to do the opposite...</span>
on Jul 11, 2011 | Cell Phones
My htc touch mobile gts switched off automatically though battery is fully charged and is new.is there a software problem or what?after getting off it doesnt start very easily.again i ve to start charging...
you have a mobile with an isemetric fault its built into the pcb due to bad current draw the only way to fix it is to replace the whole pcb if its new take it back if its under warrenty get it fixed or youl have this trouble for the remainder of the phones life.
this fault normally comes with the phone. it is not a fault that it picks up along the way
best of luck
please take the time to rate this advice
merry christmas
Dec 07, 2010 | Nokia N73 Cellular Phone
My HTC touch diamond - wont start, if connected to the charger it only makes "click" noise ..lights for 1 second, then it "dies" again :(
I have this kind of problem =( . i have htc touch diamond and when i charge the phone it has 20 % batterylife , the phone is lighting BUT after 6 h i look at the battery life after charging and it has still 20% of 100 % battery life
so it has the chargin light but the battery Wont charge =(
Oct 30, 2010 | HTC Touch Diamond Smartphone
My vairy touch will not switch on,it was purchased a couple of hours and and has been fully charged as the green tick appeared but i can not get it to come on,any help would be much appreciated
when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
when a phone won't turn on and blinks red light, it 's either the battery cell
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery for longer hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Jul 03, 2010 | HTC Touch Cellular Phone
Htc touch phone locked up, can answer and redial by using green key, touch screen is in-op
You may have to do a hard reset, remove battery and memory card, replace battery, hold down on/off button & green & red buttons all at the same time. This will fully reset the phone but you will loose all stored data, which is why you remove memory card first.
Dan.
Nov 25, 2009 | HTC Touch Cellular Phone
I have an htc ozone, what is the proper way to charge it for maximum battery life? seems to drain out shortly after an all night full charge. Thanks.
I just got my Ozone a few days ago. What you should always do with an electronic device is charge it fully before turning it on. Then using it until it dies completely with no battery. Then fully charge it again for maximum battery life.
You can go to Start, Settings, More, Power, Power Management. Change the different things to make it save on power. Also a big help is Start, System tools, Task Manager and delete everything that is being used. That just turns it off in the background, it doesn't delete the program.
Aug 31, 2009 | HTC Touch P3450 Smartphone
Crappy battery length
One replace the battery.
2 when you get your new battery for the first time charge it for almost 24/hrs
over the next week use it till its almost dead then charge it at night from about 10 or 11 at night till you wake up the next morning. You may have killed you battery by not doing this in the first place.
Mar 19, 2009 | HTC Touch Diamond Smartphone
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
177 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
