I have a Sony Model #KP65WV700 Television S/N #9009465 Made in June 2003. I am getting ghosting from the red color and before that I was getting half circles of light blue lines. Can you help me in figuring out if it is the colored lights that need to be replaced or is it something else causing this problem. Picture quality is not as it was when new. Regards, Michael
  • fixit0909090
    fixit0909090 May 11, 2010
    do you have large speaker in the room with this tv,or listen to the tv loud???
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sinkI have a Sony Model - 2.gif. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
Posted on Sep 27, 2009
Left half of picture has a green ghost like shade
The sounds like the light engine is bad. Sony is notorious for blobs because of the three LCD chip inside consisting of a red, green, and blue chip. The light from the lamp is reflected and then combined back together to form a brilliant picture. Unfortunately one of the chips is bad, or has melted due to extreme heat from the lamps. This can cause the color blobs on the screen. A lot of people experience blue or green blobs in the center or on the sides of their sets.
Feb 04, 2010 | Sony KP-61S70 61" Rear Projection...
The color is off, no reds. the tint is either
Bad news is the light engine failed. Good new is Sony extended all warentys for this model till June 2010 so get this to the shop, you do not want to pay for this $800.00 light engine
Dec 29, 2009 | Sony KDF42E2000 42" HDTV
I have a KP65Wv700 Sony Tv it turns red after a few minutes of watching tv. I turn the tv off and on so see a few minutes of normal colors but start gettinmg red again any ideas
I'm afraid, its RED Picture tube problem that will be replaced.
It is qualified tech job to replace picture tube in rear projection TV because there are few adjustments required after replacement.
Please call local tech for fix tv.
Thanks.
Dec 14, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
My colors wont stay converged
put a convergence repair kit in the set that will usually repair the Issue. You can get the Sony convergence repair kit which works with your model at the following link. The kits contain the replacement parts and complete instructions www.tvrepairkits.net
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
RED LIGHT
Does the light blink?
there is a
Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Feb 07, 2008 | Sony KP-46WT500 46" Rear Projection...
Red and green colors not coming through in picture
Bad crt
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp57wv600
· Sony Picture tube recall
Jan 29, 2008 | Sony KP-57WS500 57" Rear Projection...
Red ghost
yes you are right the stks are out replace both this is good practice check the two fuses the stk cost like 10-12 dollars each good luck get back to me
Nov 02, 2007 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
