Question about Epson Stylus C46 InkJet Printer
My printer wont print it seems to be going to the left hand side
5 Suggested Answers
SOURCE: Epson rx420 printer
Another post suggests that you printer is dead -see (http://www.fixya.com/support/t354202-epsom_rx_425_just_prints_half_page) but I've had the same problem - things seem to be ok after I reset to the defaults in the main page of the printing preferences.
Posted on Mar 15, 2008
  • 7 Answers
SOURCE: printing quality
what driver version are you using?
Posted on Aug 13, 2008
tigertail
  • 163 Answers
SOURCE: Printer is printing a different colour to the right of document
First of all have you tried cleaning the filter? Open the front cover, on the R/H side you will see a dark grey "handle" - pull this toward you about 2 inches until it stops. Next on the R/H side towards the rear of the printer is a little panel which you can just pull off. Inside this panel is a green handle - pull this in/out applying slight upward pressure to clean the laser lens. Replace the covers and handles and see if it now prints clear.
If this has'nt helped, let me know and I'll go through the next procedure. Please take the time to rate my suggestion.
Posted on Feb 26, 2009
SOURCE: makes clunking noise and wont print 1quarter of
Hi, I have this problem often. I press the menu keys at the front until i get to head aligment option and i run this a few times. Also if you are printing text try chaning the colour to dark blue or some other colour, that sometimes works. Hope this helps....
Posted on Apr 19, 2010
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
It wont print out documents from microsoft word 2007
u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection 4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Nov 14, 2009 | HP DeskJet F380 All-In-One Printer
Print on left hand side of page is faded as you look to the middle and right hand side of page print is clear
Place one hand either side if printer,
Gently shake the printer left and right a few times without lifting it off the desk..
What happens is that when a laser printer is moved and is not kept level the toner will move to one side or the other, the gentle shake evens out the toner.
Jul 01, 2009 | Canon LBP3200 Laser Printer
Left hand side of card not printing
You should be able to adjust printing edges in the printer properties, or have you tried that?
May 22, 2009 | Fargo DTC550 Thermal Card Printer
Samsung clp-300 no print down l/ h side
drum or transfer belt need changing.possibly drum.
Mar 05, 2009 | Samsung CLP 300 Laser Printer
Changing default language in Canon Software for MP810
Hi I had the same problem with an ip4500
Go to printers and faxes in the start menu, right click on your printer, left click on printing preferences, this should be the second line down, the print pref. menu window will open, you may not be able to read any of this, on the top should be five tabs, the last one is the maintenance tab (has pliers and screwdriver symbols), left click on this tab, you should see all the maintenance buttons with icons inside and six rectangular buttons in the bottom right hand corner (four on the bottom and two above them), ignore the four on the bottom for now, ( with right to left languages such as Arabic the upper two buttons are on the left hand side and the button you need to click is on the left side) left click on the button that is on the right hand side of the two buttons above the other four, a smaller window will open with three buttons on the bottom, directly above this is a bounding box with a drop down arrow on the right hand side ( left side for R to L languages), click the arrow, find "English" or whatever language takes your fancy, click on it, now of the three buttons on the bottom of the SMALL window click the one on the left( right for R to L languages), the small window should close, then of the four buttons on the very bottom of the pref. window ( these are the four you ignored before ) click the one on the left, the window will close. Go back to printers and faxes, right click on your printer, choose print pref. and your menu should be in your new language. Hope this helps.
Oct 16, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Printing too much too the left hand side.
I had a similar problem with another model. I went on line to the Co. and got all the info I needed.
Apr 25, 2008 | Xerox Phaser 6100/BD Laser Printer
Epson rx420 printer
Mar 03, 2008 | Epson Stylus RX425 Multifunction...
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
Epson Stylus C46 InkJet Printer Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
