Question about Goodman CLQ36AR49 Air Conditioner
Home ac compressor fan won't turn all the time.
Sometime when ac kicks on, the compressor fan doesn't turn. After a nudge it starts to spin normally. When it didn't turn though, the compressor and indoor system was running normally. The compressor and outdoor unit was getting really warm. Before I was able to shut it off.
How much should it cost (approx.) to have the fan motor and capacitor replaced? It's a 1/4 hp 1075 rpm 60 hz motor w/ 4 bolts pointing up.
Fan motor is: AO Smith Model# F48F97A76. Don't know about the capacitor though.
Also, had someone suggest I move to a 1/3 hp motor. What do you think? I do live in PHX, very hot.
    President:
  • 1,922 Answers
Your looking at $175-$225 for just the single phase motor depending where you purchase, I just replaced mine(identical unit) due to screaming dry bearings, if you replace it your self make sure to keep new wires tight along side of unit or fan will cut them if loose and its a fan- 5mfd/25mfd compressor@440volt cap
Posted on Sep 27, 2009
Testimonial: "Thank you, you gave me exactly what I asked for. Now I can shop wisely. Tim"
Could cluster fuse be prob why ac blowing hot? fan blows but hot air
Does the Compressor kick in when you turn on the AC? If it doesn't, the AC compressor is governed by the ECU. My AC went out along with an acceleration problem. hard starting, and unburnt fuel. I had my ECU rebuilt, and upon installation of the rebuilt unit, all worked perfectly again, including the AC.
Nov 08, 2012 | 1993 Lexus Ls 400
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Jan 06, 2018 | Kenmore 73055 Air Conditioner
Cooling fan won't come on when I turn on the AC
Your bigger problem is the compressor not kicking in. The cooling fan is not coming on because there is not enough high side pressure to turn the fan on. I would start by checking power to the compressor, fuses and relays would be inspect. Check to make sure there is the proper charge of refridegerant in the system.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jul 29, 2012 | 1988 Chevrolet Cavalier Z24
Compressor and fans do not turn on until rev engine
I passed this question the first time I read it, so I will take a stab at it now.
The fans don't come on until the compressor has pumped the freon pressure up to say 150 or 200 psi. And the compressor clutch has to have voltage to engage the clutch.
I wonder if the clutch is going and needs 14 volts instead of 12 to engage ? Or the relay that powers the clutch ?
Speeding up the engine would increase voltage from the alternator.
This is assuming the serpentine belt is tight and everything else is working correctly.
I think I would swap the relay with another and put a meter on that circuit to the ac clutch to see what it takes to engage it.
Jul 24, 2012 | 1992 Buick Regal
Motor hums but won't kick in
Hi simpsonruth1..
In the back of the compressor motor you will see a fan, remove the plastic cover to get to it..
Once you have the plastic cover removed and the fan exposed, plug the compressor in and spin the fan with your fingers...be quick as the fan could cut your fingers if you do not get them out of the way..
If the compressor starts working, then the start capacitor is bad on the compressor...if it does not run then you have motor troubles, either replace the motor or get it rewound.
Please take time to rate me
Sep 06, 2011 | Paasche 1/8 HP Diaphragm Compressor
The compressor is running and the fan is running but it is not cooling. The refrigerator runs and stops like normal. Last time we had it checked the repair guy said it was the fan not spinning fast enough...
On the refrigerator and after sometime hold the condenser to see if it is hot, if it doesn't become hot then there is no refrigerant in the system there must be a leakage somewhere or it could be the compressor which is losing compression or doesn't pump well.
May 11, 2011 | Hotpoint RLA50 Refrigerator
Ac doesn/t blow cold air
There could be a leak in your a/c system. Does your a/c compressor engage when the a/c is turned on? To check, locate the compressor, its a big cylinder on the serpentine belt, you should see the wheel engage(spin) and disengage(stop) when the a/c is activated. If it doesn't move, then your compressor is bad. If it does move, then there is a leak in the system that will need to be repaired.
The AC compressor looks like this:
http://www.partsgeek.com/gbproducts/MC/2226-07026167.html?utm_source=google&utm_medium=ff&utm_term=1991-1993+Jeep+Cherokee+A%2FC+Compressor+Four+Seasons+57632+91-93+Jeep+A%2FC+Compressor+1992&utm_content=MC&utm_campaign=PartsGeek+Google+Base&fp=pp
May 04, 2011 | 1993 Jeep Grand Cherokee
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Outside compressor fan won't spin without a nudge
either you can lubricate it by spraying wd40 on the bushings. Although usually fan motors are permanently lubricated there are still dust particles that get through and cause it not to spin.
May 21, 2009 | Carrier 38CKC024 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
964 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
