Question about Electronics - Others
USB Data Key
I'm having trouble with my Imation 1GB USB device.
Firstly I think there is a virus on the key - any idea how I get rid of it?
Secondly, when I work on say a word document on my Laptop (which has Microsoft 2007) and save to my key then insert the key into my PC (which uses Microsoft 2003) it won't let me access that document or any files I have on the key. Any ideas?
  • 170 Answers
Ya,virus in your usb key.
the virus is blocking the rights to acess the documents
install a good antivirus ,always update the virus database
try downloading the avg antivirus home edition,its for free
and it is good
Posted on Dec 18, 2007
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Not able to start imation usb ext hard disc apollo 250 in windows 7
For that you need change some registry keys and delete upper and lower filter with below method. First make sure usb cable connected to harddrive is working fine. Try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Sep 13, 2011 | Imation Apollo (27223) 250 GB USB Hard...
I have recently a product called imation. I have no idea what function it performs on my iMac. I want to back up some stories I have written onto either a disc or whatever you can recommend. I have recent...
well, you can get a external hard drive. if your looking at up to 32 gigs of data, it can be as small as a usb key. if its anything more, i reccomend a terabyte harddrive such as the passport by western digital. every mac has a time machine capability which will automaticcally back up your data good luck!
Jul 24, 2011 | Apple Imation SuperDisk Drive
My "imation apollo 25-PHDD
You need data reovery help. This guy does it remotely and works from donations. FreeDataRecovery.us
Jul 13, 2011 | Imation Apollo (27223) 250 GB USB Hard...
Dont know brought this at officeworks 4GB imation ( pocket) but now it reads as a 1GB usb
hi kindly format your usb i guess it was infected with virus thats why your usb not registered the full total of memory, cause the virus infected the auto inf of the usb. thanks
May 09, 2011 | Computers & Internet
My blackjack II hangs at the windows mobile splash screen
It must have been something you have installed. I think you'll have to hard reset your device, in order to get rid of your current status. You, most probably, know that a hard reset will set your device to its factory defaults, thus deleting all programs you have installed, as well as your personal data. Hope you have a recent backup, to be used to restore your settings afterwards. Anyway, to hard reset your device, firstly turn it off. Then, press and hold the directional pad UP for a couple of seconds, and, then, press the power button to turn it on again. Keep holding the key until some instructions come up on-screen. Follow them.
Hope your device comes back to life soon.
Cheers! Carlos
Mar 05, 2010 | Samsung BlackJack
I have an 8G Imation flash uSB. It has worked fine till recently but when I insert into port now it shows the files with hieroglyphic names and says it can't open them. Is there something I can do? Thanks...
i think you can defrag a usb drive, if it shows on your 'my computer' list of removable drives- you might try this- you can also run an anti-virus check on it, if you have an anti-virus prog. if that don't work, and the data is stored on your hd, then try re-formatting it.
if that don't work, toss it, and get a new usb flash drive!
good luck!
Oct 04, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Virus
Yep Formatting certainly will get rid of virus ! But if you do not want to lose your contacts or personals datas you can try free antivirus softwares for symbian phones
also tips to format :
Here’s how you can remove, clear and clean the virus from your Nokia cell phone :
1> Remove the memory card from your cell phone and keep it in a clean and safe place. 2> Turn on your cell phone and key in #7370# 3> Security code prompt comes up, if you have set a security key, then key it in, else key in the default security key which is 12345.
This step is actually hard resetting your mobile phone. Which means that you might lose all data if you have not backed it up and moved it on to the memory card. Hence it is very important that you remove the memory card before performing this process.
Chances are that your memory card may also be infected by the virus. To remove the virus from memory card, put it on a card reader, connect it to your PC, either run one of the latest anti-virus software on it or format it if the anti-virus fails to remove the virus (You’ll end up losing the data here), which should clean it up.
Put the memory card back in your cell phone, restart the cell phone, which is now clean of the virus.
Jun 23, 2009 | Nokia 6630 Cellular Phone
Sandisk Cruzer 1GB drive suddenly not working
DO NOT panic! Try this: restart your computer and plug your USB in again(this helps to clean the buffer), see if you drive can be recognized.
If you still can't access the data inside, try this data recovery program Wondershare Data Recovery. Get the program here,
Mac Data Recovery (Mac OS version)
Windows Data Recovery (Windows Version)
Take care - Before those items are recovered, stop saving more files to the USB in case the file data are overwritten!
Feb 19, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer titanium
If your pc infected with the strong virus ,and there are so many virus in your usb drive. you can not find the hidden file ,
Follow the bellow link ,you can get a solution from.
http://www.fixya.com/support/t7700913-usb_not_formating
If you want to remove,virus can remove in different way,please follow bellow link.
First try to restore ,
There are two way to restore the system for your OS.
  1. Start PC
  2. Hold down or press the F8 key frequently.
  3. Soon a text mode windows will appear.
  4. Select SAVE mode using down arrow key.
  5. Enter
  6. Select your OS
  7. Enter again
  8. Wait
  9. Again an windows will open
  10. There will be two option YES /NO
  11. You will click on NO
  12. Now you can restore your OS
  13. Follow this links with pic
  14. Now you should select previous date
  15. http://support.microsoft.com/kb/306084
  16. OR http://bertk.mvps.org/
  17. Or http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
  18. Hope it will help you
  19. .
If the same problem do another,
http://www.fixya.com/support/t7665080-dell_inspiron_1501s_card
Hope this helps,
May 08, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Electronics - Others Logo
85 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
