Question about Air Tools & Compressors
Air compressor wont build up pressure
When i took the head of there was a broken flat piece of metal,looks a bit like a washer with a slot in it would this be the reason thanks. Rob.
    President:
  • 1,167 Answers
Yes buddy this sounds like the valve its difficult to tell whats happened if you send me a pic i can tell you where it goes
Posted on Sep 27, 2009
Wont build up air.What could be the problem
leaking pressure hose from cilinder to tank leak pressure switch a dirty check valve on the tank open it and look for a smooth clean rubber valve that can free move and no metal pieces in it if that is there found then a part in the hose line or membrane plates are broken , if you have a dry(oilless) compressor the piston ring and cylinder may be worn.
Several possibilitys depends on models The pressure reducing valve can also be faulty leaking drain at the bottom of the tank leaking the safety valve must be good closed and also the little pressure release unit the small black hose oft in many models in the pressure switch must be closed by start there can also some dirt comes in. .that it will not close and then its continu blow of normal you can hear that it closed by starting and always release the pressure air for the next start .
Jan 09, 2016 | Air Tools & Compressors
What's wrong with my oiless air compressor
Sounds like the reed valve or valves in the head failed. When you unbolt the head you will see a thin piece of metal that is the valve assembly. If it is not all one piece it is broken and needs to be replaced.
Apr 25, 2014 | Garden
There is no air coming out in the regulated pressure
ya screw it in to up the preasure.. still dont work remove it and work with out it.. need it buy one at hobo freight there around 10 buck
hey if'n i was of help please tell me..thanks jay
Sep 12, 2010 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Need to know where the 2 little metal pices go between the head and block and gasket model ac2003 it runs fine just no air after i changed the head gasket
if you're not getting pressure those may be your valves, are they flat thin metal pieces, looks something like feeler guage material. if they are they go on the top of the valve plate to keep the air from reentering the cyl. head
Mar 13, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Compressor tamk pressure
That small piece of rubber came from the compressor pump, more than likely you have a broken valve or blown head gasket in the pump, that is why it will not build pressure.
Feb 02, 2010 | Craftsman Air Tools & Compressors
Compressor 25 psi thats it
I assume it keeps pumping, but doesn't build any more pressure. That is probably bad valves or rings. If your unit has a crankcase breather, and it is puffing alot of air, look for rings. Otherwise valves.
Dec 15, 2009 | Campbell Hausfeld 26 - Gallon Air...
Craftsman 1 gallon direct drive oil filled wont build air pressure
It sounds like you may have a broken reed on the diaphragm plate. This is located at the block. Remove the cover, and look for a cast metal assembly with fins. It will be attached to the side.
Apr 18, 2009 | Air Tools & Compressors
6 gallon proforce air compressor not building any pressure
You might have a broken valve. You'll need to pull the head apart. But make sure replacement parts are available first. Does this unit have an unloader valve on it ? That could also be your problem. You probably should check this first
Mar 31, 2009 | Coleman Proforce 6 Gallon Air Compressor
I have a husky compressor, model number y6010-wk. it builds pressure slow, and shuts down right away.
Problem: My compressor is not producing the air that it once did. It takes twice as long to pump up.
Solution:
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
4)Remove the head off of your pump.
5)Remove the valve plate off of your pump. It may be a one piece or a 2 piece design.
6)Inspect the valve plate for broken reed valves or broken gaskets above or below the valve plate.
Feb 27, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Nov 26, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
43 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
