Question about Sharp R-1610 Microwave Oven
Microwave hums and panel lights up when plugged in
Microwave also seems to come on by itself whenever it feels like. i do not thing it is actually cooking but it sounds like it. sometimes it is quiet and other times it is either humming, or the fan is on, or the panel is lit up or it sounds as if it is in use. it is an over the range convection microwave (sharp). no model number as though it was installed in house when house was purchased. thanks for helping.
  • 909 Answers
To many variables and testing needed to explain, but my feeling is that the board is faulty. Have had that happen on a few occasions but with a different brand. On occasion ive seen microwave come on when door is opened but that was loose limit switches for the door latch. Normally humming is due to a faulty magnatron, but it can also be from incorrect voltage onto the magnatron due to the faulty board. Need to concider if repair cost is worth it even though Sharp is excellent microwave.If you do, i would start with the board.
Posted on Sep 27, 2009
Hi, we have an electrolux builtin microwave.when on standby it occasionally makes a crackling noise not unlike a laptop or storage device when it looks for data. Microwave runs fine otherwise
You really need to be sure it's not running by itself - even intermittently - because that can cause arcing damage, or even a fire.
If you're not sure, leave the door open or the oven unplugged until you're sure it's not or it's fixed.
You can keep a cup of water in it and check it hourly over the course of a day to see if it coming on and actually heating.
It really shouldn't make any noise when idle except a gentle 60Hz hum.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information.
* on the tag in cooking cavity or around door frame or control frame or on back
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 02, 2017 | Electrolux Microwave Ovens
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
Advantium display reads "nite"
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Feel free to contact me directly (see below) if you have other questions.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Nov 30, 2017 | GE Advantium 120 Convection/Microwave Oven
I have a GE Profile Spacemaker XL 1800 JVM1860SD microwave that recently started making a zzzzzzzz noise whenever it is plugged in. The light also seems to be stuck on. The noise seems to be coming from...
That would be a defective electrolytic on the control circuit board.
We see and repair this problem often with our $39.95 service. Details are here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jul 09, 2011 | GE Profile Spacemaker 1.8 Cu. Ft....
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Mar 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave seems to work but does not heat food
OK, you may have a damaged thermostat or, the Magnetron may be damaged as well. you can test each device with a meter(ohm,volt).
replace any parts that dose not register.
Jun 03, 2009 | Panasonic Microwave Ovens
WST3501 Problem
We have had problems like this before. Most likely the smartboard is defective.Check with manufacture to see if there is a recall.You should be able to find them on the web.
Nov 02, 2007 | Microwave Ovens
Makes a loud humming noise while operating
Almost certainly, the component called the "magnetron" has died. This is the valve (tube in the US) which actually generates the microwaves. The loud humming is the transformer that supplies the magnetron being overloaded and/or the magnetron itself. If the rest of the appliance is OK and not too old, the magnetron can be replaced. If you aren't familiar with these appliances, you *must* get this done by someone who understands the dangers of messing with them - if you get it wrong, they can bite! In some countries, only qualified engineers can buy the spare parts. In the UK, the part costs around £40 - £80, depending on the model. If the appliance is more than around three years old, it may be a false economy to repair it as other parts may fail soon after the repair.
Sep 24, 2007 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Sharp R-1610 Microwave Oven Logo
143 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
