Question about Cell Phones
I want to transfer my contacts from my nokia 6500c to my blackberry via bluetooth but connection fails when I try. I am paired with it. Why?
    Sergeant:
    Champion:
  • 203 Answers
Hey, make sure that bluetooth device is on, then some celphone has a passkey before connecting it to other phone, make sure to use same passkey on both phone.
Posted on Sep 27, 2009
Paired backberry 8520 with parrot ck3100 but contacts will not syn with parrot. tried to transfer contacts to parrot but message just says refer to handsfree maunal .have looked into this with no luck...
Hello chicks,
Pairing both devices from the Parrot Product:
Select Setting / Advanced Settings / Pair with phone / Other phones
* From the phone:
* Select MENU / OPTIONS / BLUTOOTH / ADD DEVICE / SEARCH
* The phone will search for available devices
* Select the Parrot Product name from the list, and enter the PIN code '1234'
* The phone will pair with the Parrot Product and auto connect
Sending contacts via Bluetooth For all contacts sending
* From the phone:
* Select MENU / MANAGE CONNECTIONS / BLUETOOTH OPTIONS
* Select the Parrot Product from the list of paired devices and go to OPTIONS / TRANSFER CONTACTS
May 07, 2011 | RIM BlackBerry Curve 8520 Smartphone
The issues i am facing are as follows 1)Cant pair my iphone 3gs via bluetooth to other phones 2) How do i transfer contacts from Nokia to Iphone Please let me know the solution to the above stated at...
Hi. For the iPhone bluetooth, it can only connect on another iPhone device and not on any other devices. So that is the reason why you were not able to transfer contacts from your Nokia phone to the iPhone if you have been trying to transfer it using a bluetooth connection.
Hope this helps. Have a great day!
Mar 28, 2011 | Apple iPhone 3G
Bluetooth will not connect
pair your device and select connect to in bluetooth settings
May 08, 2010 | LG Lotus Cell Phone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
Phone Book Transfer Nokia N70 - Blackberry 9000
Syncronization! The Nokia phone will not just easily transfer or sync the contacts to your Black Berry because they are running on 2 different softwares.
In order for you to transfer all the contacts to your Black Berry is through synchronization
The Nokia N70 came with a CD called the Nokia PC Suite. And Black Berry should have a sync software.
What are the things you need:
1. Computer
2. Nokia N70
3. Black Berry phone
4. Nokia PC Suite CD
5. Black Berry sync software
How:
1. Install the Nokia PC suite to the computer.
2. Connect the Nokia N70 to the computer.
3. Export all the Contacts from Nokia N70 to your computer (refer to the manual)
4. Once the contacts are saved in your computer, disconnect the Nokia and connect your Black Berry.
5. Run the sync software of Black Berry and import the Contacts that are saved in the computer going to your Black Berry (refer to the manual of Black berry).
This is hiow to transfer the contacts from one phone to another.
I would also suggest to contact Nokia so that you will have a clearer idea on how to do it.
May 23, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Transfer data from Nokia N958GB to i phone 3G
go at your blootooth profile and paired this ph and get connected
Apr 04, 2009 | Nokia N95 Cellular Phone
Blackberry 8110 - cant receive bluetooth stuff
with a blackberry you have to go to the media player, go to music for music and then hit options receive using bluetooth
Dec 03, 2008 | RIM Blackberry 8110 Cellular Phone
Blackberry Itune/media player/mp3 player/bluetooth operation
alright bhavin,
all you need to do is first PAIR your both the devices using bluetooth, then in black berry on music or ringtone or picture whichever you want go to.. menu-->option-->receive using bluetooth ,,,, once you allow files to be transfer from nokia you will receive in blackberry... and for sending out from black berry... select SEND USING BLUETOOTH....
i was doing the same to transfer between my nokia and blackberry phones...!!!
but for downloading this particular files, i never this so sorry about it..!!
Sep 25, 2008 | RIM BlackBerry 8700c Cellular Phone
Rim blackberry 7290
let me start by asking you .. are you receiving it at all? or does it say it failed?
Jul 31, 2008 | RIM BlackBerry 7290
Cell Phones Logo
363 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
