Hi i am installing autocad 2010 64 bit on my notebook hp 64 to do so i use a key generator xf a2010 64 with winrar390 when i enter the code to get the key and then use the mem patch i get the following message: could not get debug privilege! are you admin? what can i do to solve this please?
  • 2 more comments
  • corcovado5 Sep 27, 2009
    vinay
    thanks
    but this is a copy and it worked with all other students
    when i installed it with dvd, i had to enter a serial code and a password that i was given
    and then when i wanted to activate autocad the problem occured...
    vinay
    this is the install text: what does n.2 of the NB below mean? thanks
    0.Read the complete install procedure before starting.
    1.Install Autodesk Inventor
    2.Use as Serial 666-69696969, 667-98989898, 400-45454545 .. or anything matching this template
    3.Use as Product Key 527B1 or 462B1 (read below)
    4.Finish the installation & restart Autodesk Product
    5.Choose to Activate
    6.Once at the activation screen:
    start XFORCE Keygen 32bits version if you are installing a 32bits application and
    64bits if you are installing a 64bits application.
    7.Click on Mem Patch (you should see succeeded)
    8.Copy the request code into the keygen and press generate
    9.Now copy the activation code back to the activation screen and click Next
    YOu have a fully registered autodesk product
    NO LAME DLL PATCHING .....
    NB:
    1.Autocad Mechanical isnt included because we already released it.
    So Deselect AutoCAD Mechanical during installation
    2.Make sure you are running the Keygen as administrator and with UAC off on Vista
    but you have to anyway to install Adesk products.
    Depending on the product key you enter the installation procedure will install a different edition of inventor.
    If you want to install Inventor Standard 2010 please use the product key: 527B1.
    If you want to install Inventor Professional 2010 please use the product key: 462B1.
    We do not differentiate the Inventor Simulation or Inventor Routed Systems Product.
    Inventor Professional contains all the functionality of Inventor Routed Systems and Inventor Simulation.
    vinay
    what s uac on vista?
    thanks
    L
  • corcovado5 Sep 30, 2009
    yes accepted
    good
  • 497 Answers
Check this link to disable the UAC of Vista.
http://www.howtogeek.com/howto/windows-vista/disable-user-account-control-uac-the-easy-way-on-windows-vista/
Also try running the Application as Administrator and check.
To run the application as Administrative:
Right click on the application and select the option "Run as Administrator".
Good Luck!!!!!!!!!
Posted on Sep 28, 2009
    President:
  • 1,884 Answers
Simple. It means that only the administrator is permitted to install programs on your laptop. And since your are not logged in as administrator, ACAD will not install. So, get admin passwd and login as administrator. All will install like a breeze.
Posted on Sep 27, 2009
  • Vinay Tevatia
    Vinay Tevatia Sep 27, 2009
    I am not doubting the DVD. Yes it may have installed on other computers. The question about admin as you said initially is about the admin rights of your laptop. It is your copy of Windows that has the problem. You are not logged in as administrator and hence Windows is not allowing you to install ACAD.
    SO, like I said earlier, get hold of admin rights and install ACAD.
  • Vinay Tevatia
    Friend,
    You must read NB 2 which say clearly that you must be an administrator to run keygen or whatever it is. If you are then it will not generate the key and off you go. No key No ACAD. You must see the rights that administrator has and compare them to what you have. So, administrator passwd is a must in your case.
Xf-a2012-32bits
You won't find activation codes or keys here.
Contact Autodesk for purchasing.
Jan 26, 2014 | Autodesk AutoCAD LT 2012 - 10 Users...
I am trying to install autocad 2012 in my HP laptop with windows 7 version, but after the keygen code is generated & i paste it in the autodesk window, it shows activation error (0015.111) can any
If you are patching some sort of keygen then you are trying to bypass the authentication of AutoCAD. You should purchase the product if you want to use it.
Aug 11, 2012 | Autodesk AutoCAD LT 2012
Autocad r14 serial numbers.help
HI,
The cd key was printed on the CD case together with your installer, you can find it on the back.
Thanks
Feb 06, 2010 | HP Computers & Internet
I cant install autocad 2009 in windows vista 64 bit operating system.
I cant install Autocad 2009 on Acer Apire 5715z, when i try to install the operating system is not supporting
regards,
Johnson Idukkula johnsonkollam@gmail.com
Mar 05, 2009 | HP Pavilion dv4000 Notebook
Autocad is not inastall
Vista is 64 bit O/s & your cad is not supported the application & also your cad is not vista verson that,s why it is not working, if you want to use either change the O/s or cad.
Mar 05, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
508 people viewed this question
David Payne
David Payne
