Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch 2460uc washing machine give water tap closed message, pushing start button 7 or 8 times per cycle to complete cycle. inlet screen on both ends of hot and cold hoses are clean. Water pressure on nearby sink is normal
Water tab goes off all the time, get rid of machine, don't buy Bosch
Posted on Jun 02, 2011
Bosch exxcel washing machine
try checking/replacing the inlet water valve. hope this helps
Nov 24, 2013 | Washing Machines
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
During every cycle, I get a "check water tap" message? It stops running and beeps until I press the start button again
Welcome to FixYa.
What happens when you press start again, does it continue on through the cycle or display error again ?
Typically this message indicates the water is shut "off", a hose is "kinked/pinched" or a small screens/strainers inside the fill hoses has become blocked or partially blocked.
If you turn off your water and remove the hoses from both ends, clean out the screens in the hoses and in the valve, that may remedy the issue.
Let me know what you find and we can go from there.
Good luck.
macmarkus :)
Aug 26, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch SHE45M Odor? What can I do
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean. Do this on a regular basis.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Add 1/4 cup (60 mL) of liquid chlorine bleach to tthe machine. DO NOT use more than 1/4 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C) if you have one or use a 60C wash. DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure as necessary.
Sep 30, 2009 | Bosch Dishwashers
Rid of Mildew Smell?
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
7. Repeat the cleaning procedure monthly
Aug 22, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
A mold smell from my washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Dec 28, 2008 | Bosch Classixx WFO 2466 Front Load Washer
WFS1071AW is my type of whirlpool front loader
Hello baud Welcome,
You said the water entry into the machine is fine with nothing blocking it. But you keep getting the red light on for "water tap closed". At one point the water did start flowing in but soon stopped and turn on the warning light again. Please suggest how to fix it??
I believe this sounds like the screens are dirty and stopping water flow so it shuts down!
Dry all of the below suggestions.
Washer displaying code message and or tone sounds
“F20” (Water Inlet Problem—no water or insufficient
water supply)
First:
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.Leave power off for 5 minutes. This will reset the system!
Check the following:
Are water faucets completely turned on?
*****Are screens at inlet hose connection to washer clogged?
Remove hose from washer an clean screens at water inlet!
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Let me know how you do.
Thank You Huuum
Please remember to leave a rating!
Oct 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
Dec 08, 2007 | Bosch Axxis WFL 2060 Front Load Washer
"tap water closed?" message
Plug off the wall. Check the inlet tubes into your machine (after shutting off wall valve) for any blockage or clogging, both ends of the pipes. Refix carefully with correct threading. Turn on before next wash fully; and after wash turn off valve. It could also be that your wall valve is not on fully when you begin your wash.
And dont forget to rate me pl.
Jul 03, 2006 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
569 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
