Question about HP Officejet 5610 All-In-One InkJet Printer
I can't print a pdf file with officejet hp5600
I can't print a pdf file. While printing the file a msg pop up as: unable to strat print job, is printer available?... and when I click ok nothing is happaned.
  • 80 Answers
please check if the print spool service is working or not.( start - run - services.msc)
Posted on Sep 27, 2009
My printer won't print ADOBE files, but prints all word documents
I believe you are misunderstanding what you're "telling" the computer to do. You are telling the computer (I assume in Microsoft Word, but perhaps elsewhere) to generate an electronic document in PDF format. (I believe PDF stands for Portable Document Format)
It uses a printing metaphor because like a paper copy, the PDF file is designed for people to read, not edit the document you have created. Also, some PDF-making software methods involve pretending to be a printer, which allows the user to make a PDF file in any program that would normally only output your work to a printer.
Most people, when wanting to print a PDF document onto paper, open it with Adobe's Acrobat Reader (which is free software) and print the document from there. For sharing a document that you want no changes to, this is a superior option to sending people an MS Word .doc (or .docx) file, which does not have its information "locked" onto virtual pages in the file.
I hope this helped!
Jan 18, 2010 | HP DeskJet F380 All-In-One Printer
I can't print pdf files from the internet, I have to "save as"1st
Sometimes the file name assigned to a pdf is not compatible with our printer's memory. For example, if the file name includes brackets [ ] or other punctuation, or is very long, the printer won't recognize it. One print job that stalls will hold up the entire print queue, so delete your job from the queue.
First, look at the file name displayed in the print server's list of print jobs. The same file name also appears in the top blue bar of your Acrobat pdf display. Are there brackets, per cent signs, or other punctuation marks in the file name?
Dec 28, 2009 | Microsoft Office Home and Student 2007...
Can't type date into .pdf file and print with HP OFficejet 8500
Maybe it is because of your PDF file is encrypted by author with owner password. In this case, you can remove the password by AnyBizSoft PDF Password Remover, and then print it again.
Hope it helps.
Nov 17, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
"unable to print" msg
you could try going into control panel clicking on your printer then click on printer top left and cancel all documents
Jul 30, 2009 | Brother MFC-5440CN All-In-One InkJet...
Problems printing pdf files with an hp officejet pro 8500
You can try installing the PostScript driver rather than the default PCL driver for the printer. You may also have a faulty USB cable which is causing data errors when printing complex jobs such as PDFs.
Jul 08, 2009 | HP Office Equipment & Supplies
Printer LCD says Cartridge Problem - Tri-Color. Refer to device documentation to troubleshoot.
Before you can troubleshoot the problem, you need to determine its cause.
To determine the cause of the printing problem:
1. Print another PDF file, such as the first page of Acrobat Help:
-- If that file prints correctly, the PDF file that doesn't print correctly may be damaged. See "Resolve problems printing a specific PDF file from an Acrobat product" in this document.
-- If the file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a .txt file) from another application (such as Microsoft Word or WordPad):
-- If that file prints correctly, the problem isn't system-wide--it's specific to the Acrobat product. However, the way Acrobat interacts with the system may affect printing performance. Go to step 3 to eliminate some system-related causes of the problem.
-- If the file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDF files. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF file:
-- If the file prints correctly, your system may have been out of memory or resources.
-- If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory, and then turn it back on and print a PDF file:
-- If the file prints correctly, the printer's memory was too full.
-- If the file doesn't print correctly, go to step 5.
5. Print from another computer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the printer or the network correctly. Contact your network administrator or consult your network documentation.
-- If the file doesn't print correctly, go to step 6.
6. Print a PDF file to another printer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the original printer because of a communication, hardware, or memory problem. Make sure that the printer is turned on and connected properly, and then run a self-test on it to make sure that it's working correctly. For instructions, see the documentation that came with the printer. You may want to contact your network administrator for assistance.
-- If the file doesn't print correctly, see "Resolve problems printing any file from any application" in this document.
you can try these option and then try to resolve them and you can find the solution on follwing link==http://kb2.adobe.com/cps/316/316508.html
For more free tehnjical support you can visit-----http://tinyurl.com/lkrpwy
Jul 06, 2009 | HP Officejet J4680 InkJet Printer
Msg saying unable to start print job. is printer
Uninstall the Adobe PDF viewer and then reinstall it as the printer is respondingto other print commands,so its an issue with the s/w you are using.
Jun 11, 2009 | HP PSC 1410v All-in-One Printer
Cannot print from hp5600 all in one.
1) we will check that printer is start or pause.
2) If first condition is correct,then OPC drum is filled or not.
3)If both conditions are right, then there should be Hardware problem .
Apr 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Msg 'unable to start print job, is printer available'
A customer called me with the same msg. Let me explain first what the problem was..they had a Graphic PDF that on the HD was 20 MB but when extracted was well over 200 MB..first I had thought the pdf was exeeding the Printers memory but after testing it was not. The customer was printing the document using adobe PRO I had him print the document in reader 8.1 and made sure the print as image under advanced was selected and the document printed..
Aug 09, 2008 | HP PSC 1410v All-in-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
181 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
