Question about Refrigerators
My sub zero 650 series refrigerator is working fine but making a lot of noise like it's running all the time .What should I do . It has gotten slightly worse and I am concerned it will just stop working altogether.
  • ACME Sub Zero Refrigerator Freezer
    Need check thermistor, but I don't know if u able to. Noise from where? Behind the grill on top?
    Sergeant:
    Champion:
  • 205 Answers
Hello mam
please call the engineer and make him to check the compressor and the temperature sensor.this sensor should make the compressor to cutoff when the temperature reaches the setpoint.
Posted on Sep 27, 2009
Sub Zero dripping noise from freezer when cycles off
Is this noise periodically or every time the fridge cycles off? Does it sound like water dripping on a hot surface?
Sub Zero Repair Tucson
Dec 05, 2012 | Sub-Zero 650 / O Bottom Freezer...
My 650 F makes a rattling sound
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Feb 19, 2011 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650
It is the newly adopted power saving technique. There's nothing to worry about it.
Apr 20, 2010 | Sub-Zero 650/SRH Stainless Steel
The freeszer door on my Sub Zero does't have suction anymore
what is the mod num> 650, 700? no a lot help. check the freeze inside the upper part for any ice build up
Apr 02, 2010 | Sub-Zero Bottom Freezer Refrigerator
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Gurgling noise
gurgling noises are not unusual - after all there is a gas/liquid mixture being circulated
Sep 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 561
You are number 3 in the series this AM-
As you probably know, the recommended temperature range is between 35-45 F so if you control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be a problem with your brand; I'd check to see if there is a recall or factory 'fix' for this. They may have gotten a batch of defective sensors or controllers.
Aug 01, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 500 series
Yes you need a new fan motor... check the blades that there are free... door jams have heaters and will be hot this keeps them free of frost...let me know if I can help
Jul 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 532 not cooling
Simple think I guess - just pull down a little a plastic fan blade on motor shift it will produce a powerful air flow. Fan blade should sit pretty close to the shift end. ;)
_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jun 11, 2008 | Sub-Zero 632 / S
Sub-zero 650 / bottom freezer
Clean fluff from condensor, turn off overnight and defrost, turn back on following day should start to work ok within 24hrs. Regards Advisor
Aug 09, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
