Hi lg projector av1 clour is become
Hi lg projector av1 clour is become black.other av's are ok
2 Suggested Answers
  • 11800 Answers
SOURCE: LG 52SZ85RTB\r\nWhat would cause all 3 AV (AV1,
A faulty  AV switching IC - the chip must be replaced. But i must say that this is an extremely rare fault - i've encountered it only once in my career, when a lightning fried a sattellite receiver - so you better check the cable connections and the source of the signal.
Posted on Aug 31, 2010
No picture just av1
If the cat sat on the remote, it is likely it changed the tv to AV1. Just find the AV button on the remote and press it again and again. It should cycle through the different AV channels your TV has - my TV has 6 AVs, 2 HDMI and a PC channel so if yours is anything like mine, you may need to press several time to get back to your Sky/freesat/virgin box. Alternatively, some HDMI connected kit just needs turning off and on. That then sends a signal to the TV which changes the TV automatically. For example, my Blu-ray player does that.
Experience - I have a cat that sits on my remote and does the same thing!!
Jul 31, 2012 | Panasonic 37" VIERA Full HD 1080p IPS LED...
HI I HAVE A LG TV 32LC7D AND I HAVE A PROBLEM WITH IT WHEN I TURN ON THE TV IS ALL BLACK AND IS ONLY A 47 CHANEL SHOWING IN THE SCREEN AND NEED SAME HELP TO REPAIR THIS TV
Hi
I have met this problem with my LG.
I agree unplug from the power supply and find the correct input on the remote control. OK the antenna if that is your input. AV1 or 2 if you use ADSL.
Good luck
Kolbrun
Jun 09, 2011 | LG 32LG30 32 in. LCD HDTV
Toshiba back projector 43' how do i make the av
Look at what input you plugged the DVD player into. maybe AV1 or AV2
Now on your remote, or on the front of the TV, push input until it stops on the one that your DVD player is plugged into.
Aug 27, 2010 | Toshiba 43HX70 43" Rear Projection...
When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Oct 24, 2009 | LG Televison & Video
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
