Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My 52" dlp 1080P says check airflow and turns off. In same location for two years no dust bunnies air flow seems good, what can i do
  • 115 Answers
That is a tricky sympton for that model . You'd expect it to only be prduced by the lamp temp sensor but the chassis fan stopping while tv is on can also produce that message on that model. I'd reccomend taking it to a repair facility . The chassis fan is the fan you can just see the edge/top of on the left side above the input jacks (looking at the back of the set with the back and the inner metal back removed). Other devices could possibly produce that mesage ,that model has 5 fans inside it! Temp sensors too.
Posted on Sep 30, 2009
How to test fans on dlp tv I have pulled the video engine
Hello. Most fan problems are dust related, and only need cleaning. A can of air should do the trick.
Oct 14, 2015 | Mitsubishi WD-73738 73 inch DLP 1080p...
HP Pavilion dv1000 PC Notebook My PC shuts down automatically
This is a common problem for many laptops.Its shutdown because of over heating.msoufeer5_2.jpg
Each mobile processoe has a max temperature rating. when the temperature reches certain degree
the processor shuts itself down to prevent damaging the chip.The number 1 cause of heat related issue is dust bunnies.
Dust is a pretty good insulator and it will block your laptop's airflow when it build up over time.The easiest way clean it is to use a can of compressed air and it through the air flow event.
If you are handy you can also take out the key board and clean the inside. you can see the cooling
fan on most laptop once you removed the key board.In some case even the out side look clean but
if you take apart the fan assembly you will see tha ther's still dust collecting inside
Clean dust and try again
PLEASE VOTE ME AND RATE IT
Sep 05, 2011 | HP Pavilion dv1000 Notebook
I've samsung home theater model HT Z215 it's turning off after one minetue , a messege appear in the panel " fan CHK" would you please help me to fix it. kind regards;
It's telling you the cooling fan is not working effectively. Look for the dust-clogged air inlet and unclog it, maybe even go inside the unit and rid it of any dust bunnies. Ensure the whole unit has good clear airflow around it.
May 20, 2011 | Audio Players & Recorders
How do i clean the filter on my vp6325 projector?
If you have a jet air - compressor or blower- use it to clear the filter of the trapped dust within the filter. Once the filter is clean the flow of air to the lamp unit will be improved and so give you longer life on the lamp. A tiny bristle type brush can be used-- the brush of your electric shaver.
Jan 18, 2011 | HP vp6325 DLP Projector
My TV shut off recently and just before it shut off I got an error warning that something was wrong with the airflow. Now it won't turn n and it keeps flashing yellow. Someone please help!
first things first. is this set a dlp or a lcd if either it will have a projection lamp and when the filter for air intake gets clogged with dust and dirt it will cause the lamp to fail before its time is up.. have the lamp replaced by a tv service man..goodday.. p.s. expect to peel off about 300 skins..
Nov 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Air flow blocked message appears when turning on
Replacing the thermal sensor is the cure for this. If you call Mitsubishi at 1-800-332-2119, press 5 for Customer Service. Explain the problem and they will probably approve a extended warranty claim and get the repair done for free through a Mitsubishi Auth. Repair Facility. They will also help get you in touch with one near you. Do not delay in acting on this. I do not know how long the extended warranty claims for this problem will last.
Hope this helps,
Skyassoc
Jun 20, 2009 | Mitsubishi WD-52327 52" Rear Projection...
I have a Mitsubishi DLP 1080p TV with air flow problems
Hello ags98,
First I would suggest that you re-seat the bulb and then check the cooling fan, and air flow path. In addition to checking the fan make sure all air flow ingress and egress vent are unobstructed.
I hope this helps
Thank you,
Shuttle83
Oct 01, 2008 | Televison & Video
Canon W7200 Error code E02D05
The Service Manual says:
E02D05 Airflow fan error
Fan rotation could not be detected while the air flowfan as running.
Probable problem locations
Air flow fan, engine controller, system controller
Remedy
1. Cable connection check (check - replace
2. Replace air flow fan
3. Replace engine controller
4. Replace system controller
I wish success
AToe
May 05, 2008 | Canon imagePROGRAF W7200 InkJet Printer
Mitsubishi wd 57731 1080p
see if there is dust inside blocking it.
Jan 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
