Question about Canon PIXMA MP470 All-in-One Printer
At first the paper would feed through then when the 2nd paper fed through i get the msg that there is a paper jam. Now as soon as you turn the printer on it gives me the error code 5100
  • 4,041 Answers
Hi You can Try
for most canon this error code is
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Feb 01, 2010
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    Paper jam/no paper fed
    make sure the photo paper is in glossy side face down,
    set the paper type to photo.
    If it keeps jamming it's because the paper feed is probably dirty and not taking the paper properly
    Mar 24, 2010 | Brother DCP 130C All-In-One InkJet Printer
    Jam in print paper path HP 2840 printer
    does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
    May 20, 2009 | HP LaserJet 2840 All-In-One Printer
    AL-800 cannot make copies jam light remains on with no jams
    First, is the paper being fed at all? If the paper is being fed and jams at the same location then a senor, actuator or switch is bad, out of place or broken. If the device will not clear the jam light, completely power down the device, unplug from wall, let set about 30 sec. to 1 min. and then replug in and see if it reset. If the device did not reset then again a senor, actuator, or switch is out of position ( being held up in the paper path). If the paper does not feed at all then the feed section is the problem. Clean the feed tire (s) the rubber restorer or a high alcohol base cleaner. Listen to hear if the feed tire (s) are even turning. If feed is not turning then it could be clutch, motor or board problem.
    Jan 04, 2009 | Sharp AL-800L Copier
    Error msg: Paper tray empty or jam, when there is not
    Clean The Paper Feed Rollers Using The Unit's Operation Panel Ifthe paper feed roller is dirty, paper is not fed properly because thepaper feed roller slips. Cleaning the paper feed roller could resolvethe paper feeding problem. Please follow the instructions below toclean the Paper Feed Rollers directly from the unit. Caution:Since the cleaning process wears down the paper feed roller, performthis procedure only when necessary and no more than three (3) times.
    1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
    2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
    3. Press the <Menu> button.
    4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
      Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
    5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
    6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
    1. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
    2. Tocheck if the rollers are clean, load a sheet of Letter-sized plainpaper in the same paper source you selected in step 2, and press the<Open> button.
    3. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
    Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
    Paper Source
    Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
    Cassette
    Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Sourcesetting in the printer driver. If the option is not set to 'Paper FeedSwitch', paper will feed from the source selected in the driver.
    Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Canon Pixma MX310 Office printer. continues to jam paper. in the maintenance panel i cannot perform an alignment check or deepclean. Attempt to copy feeds a whole sheet thru and chokes on the 2nd piece. I...
    Printers that jam usually have worn feed rollers, some where in the machine, or a bad sensor. If worn feed rollers are the problem the paper usually jams in different locations in the machine. If a sensor is bad the paper usually jams in the same spot each time paper is fed into the machine. A new machine does not have worn rollers, but could have a broken sensor. It sounds like the a roller might be worn. There is a company called Tech Support that use to sell a cleaning fluid for paper feed rollers. You can use alcohol but alcohol dries out rubber, but you can use it to diagnose the problem. Clean all visible rollers. Especially the rollers that the paper jams between.
    Nov 20, 2008 | Office Equipment & Supplies
    HP 2840 printer paper jam
    Sep 08, 2008 | Office Equipment & Supplies
    Paper fed
    Turn the printer off and open the access cover.
    Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
    Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
    Watch the paper as it feeds through and try to determine where the jam is occurring.
    Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
    If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
    Turn the printer off.
    Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
    Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
    Mar 08, 2008 | Lexmark P915 InkJet Photo Printer
    Canon PIXMA MP470 All-in-One Printer Logo
    134 people viewed this question
    old marine
    old marine
