Question about Brother MFC-5840CN All-In-One InkJet Printer
"Unable To Change" message. Tried all suggested fixes none work. Can you provide any additional help beyond the standard fixes. Nothing is jammed, turning it off for even days doesn't remove the error message, and I don't even use the fax machine! Thanks, Paul
  • 2 more comments
  • PFPW Dec 18, 2007
    In following your instructions, the reading is: Machine Error 4F
  • PFPW Dec 18, 2007
    I tried it again two more times and the message came back: Unable To Change Trouble shoot and Routine Maintenence, the same error message I have been dealing with from the start!
  • PFPW Dec 18, 2007
    Thanks,
    So what exactly needs replacing, and do you know the cost of the part and labor aproxamently?
  • PFPW Dec 18, 2007
    Thanks, but I think I will take it to the dump!Paul
  • 832 Answers
Press menu then start bk copy then fourtimes arrow up. what error code does the machine display?
In case you have an error 50 you have to open the printer cover and to reinsert the encoder strip which is out of position into the ph. This occurs sometimes after a serious paper jam.
search error 50 for dcp 110, 115 or mfc 210 here. its the same procedure.
Posted on Dec 18, 2007
  • Mix-it-up
    Mix-it-up Dec 18, 2007
    @PFPL:
    the ph is defective and cant be fixed anymore. It needs replacing by a new one.
    (4F: Piezo voltage electric defective)
  • Mix-it-up
    Machine needs complete new printhead. Spare part with labor is more costly than a new mfc 240/260.
    My advise is to buy a new machine and sell the old one at eBay.
Nokia 1661-2 unable to use Insert SIM / Demo
you can contact this store: www.unlocksolution.com
This guyz helps a lot.
Mar 12, 2013 | Cell Phones
The thread keeps jamming under the feed dogs. The machine takes about 2 stiches and then it won't move any more, but it keeps sewing making a terrible mess under plate. What can I do to fix this...
I had the same problem and tried everything you did: rewinding the bobbin, checking to be sure I had the bobbin in correctly, checking the upper threading, readjusting the tension. When nothing I tried helped, I bit the bullet and took it to the shop where I had bought it. The timing was off; there were burrs on the bobbin case; the hook was not performing correctly;there were threads caught between the tension disks. It cost about $65 but when I brought it home, it purred like a kitten! I suggest you take it in for a check up! Especially if you've tried all the usual tests and none of them worked.
I'm sorry I couldn't give you a do-it-yourself answer but sometimes they've just gone beyond what we can do for them.
Jul 24, 2011 | Brother SE350 Mechanical Sewing Machine
Says "Paper Jan" when there is none - 8500
if you have tried the troubleshooter and nothing changes, i suggest you do a partial reset. go to this link to give you a walkthrough on how to restore the HP All-in-One to proper operation.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01631212&cc=us&lc=en&dlc=en&product=3752456&tmp_track_link=ot_search
hope this helps
Mar 05, 2011 | HP Office Equipment & Supplies
The company I work for has an old RICOH Copier that has an error message, ''Close the Finisher Door''. I've tried to open and close all the doors, checked for jammed paper, but nothing. Any suggestions?
These type of machines have actuators and micro switches, make sure none of the actuators are bent and not making contact with the switches, The actuator may be a pin or bolt that come in contact with the door switch.
Hope this is of some help.
Ed
Apr 17, 2009 | Office Equipment & Supplies
I get message that the printer is jammed. i have removed the paper and reinserted it,and the message still appears.in addition,when i press print the paper doesn't move thru the printer for material to be...
i can't find the problem.i was hoping you might have a suggestion on how to fix the problem. i will not pay to have advice given.i might uninstall and reinstall the printer. I 'am not happy with pay,and then we will help with problem,not good business as far as i'am concerned. Let me know if you care enough to help.
Nov 06, 2008 | Lexmark Office Equipment & Supplies
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
VA520 Resolution Message
Have you tried via the Control Panel/Display function?  The driver provides the means but Windows provides access to those settings.
May 24, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
554 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
