Question about Microtek C893 18.1" Flat Panel LCD Monitor
I have a Proview 2200W LCD Monitor, when i plug it in all i get is the speakers squeaking. the monitor will only work on a special occaision
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
My moniter has a black screen and is blicking blue light. i have a proview model 2200w? Was working fine until i shut down yesterday. I unpluged, nothing happened. Could it be in a sleep mode? If so, how...
this is so common in lcd monitors, its the power suply board.... most likely a capacitor.. so type a model# into google following the words "power suply" it will probably be close to $50-$60... thats better than buying a new one
hope this helps you
Feb 06, 2011 | Proview PL576Ws 15.4" Widescreen LCD...
I have a proview 22 inch monitor model 2200w it will not come on
Check power supply DC filter caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 22, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
Speakers are not working. I do not have a manual for the product. I am assuming that the speakers are built in since there appears to be no input jack on the monitor into which speakers can be plugged.
So u are using this lcd monitor with ur pc? been trying to look it around and i really dont think this one have built in speakers, u need to plug ur speakers to ur pc, not to ur monitor.
Oct 31, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Proview lcd monitor has permanent white screen
I had this exact same problem with the 2200W. I was afraid it was the logic board but that wasn't the case.
I replaced all of the capacitors on the power supply board and now it works perfectly. At first I only replaced the bulging capacitors but that didn't fix it. Most of the bulging caps were the 680's and 470's. It ended up being a 220 (which didn't even look bad) closest to the cluster of 680's.
Save yourself some time and replace ALL of the caps. I used this image from a post on this site as my guide: http://www.ccl-la.com/pl926.jpg
Jun 22, 2009 | Ergotech ET-HD1021 MP3 Player
Sound is not loud
buy separate speakers there are issues with lcd monitor speakers not being loud or powerful enough.
Sorry, but separate speakers are the easiest solution
Nov 26, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor audio hook-up
You should need a mini jack audio cable. One end plugs into the speaker port of your sound card in the back of the computer (usually marked green). The other end should plug into the audio input of the monitor.
Oct 06, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
How to get the audio to work
In checking on your particular model there are no speakers with the monitor.
Jan 02, 2008 | Proview PL926WBi 19" LCD Monitor
Microtek C893 18.1" Flat Panel LCD Monitor Logo
820 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
John Anderson
John Anderson
solver2010
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
