Question about Gateway 7330GZ Notebook
No ip address how do i fix it - Gateway 7330GZ Notebook
    President:
  • 2,600 Answers
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
If that doesn't work, here is something similar...
This is most likely due to a driver issue other than a settings issue. First off, if you are running your computer in selective startup, change it back to normal startup and reboot. If this clears the problem then great, you can go back to selective startup but be careful as to what services you shut down.
The easiest way to check if this is a driver issue is to update the driver for the device. This can be done at the Device Manager found in the control panel, (In XP, the device manager is in the “system” icon and under the hardware tab). Scroll down to the network adapters and click on the + sign. Double click on the adapter and choose to update driver, let it search the internet (windows update) if it wants to, if it finds an updated driver, allow it to install. If it does not find an updated driver, then maybe the driver you have is a recent one but it may be corrupt. If that is the case, then it would be better to right click on the adapter and choose uninstall, this will force windows to reinstall the device the next time it reboots, and again it will ask to search online for a fresh driver, choose yes and let it run. Once the device installs, try to connect to the internet.
Posted on Sep 27, 2009
Wheres the ip address found
The printer's IP address is usually assigned by the router normally under the DHCP. Some printers can be setup with a fixed IP address internal to the printer, but you must be careful not to assign it the same address as another device on the system or it will be in conflict. The beast way to assign a fixed IP to a printer is to give it an assigned IP address in the router table.
Nov 07, 2015 | Office Equipment & Supplies
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Need the IP address on a rca 46in LED
By default, the IP address will automatically be assigned by the router. If you want to set a fixed IP address, there is a menu option to do so under SETUP on the television. You may enter any fixed IP address within the accepted range of your router. (It is recommended to set the television to DHCP mode so it will automatically be assigned an IP address by your router.)
May 26, 2014 | Computers & Internet
Where is IP address for the MFC-7220 printer
Network printers do not have a set IP address, you need to configure the printer with an IP address that uses the same range of IP addresses as your network.
The IP configuration is normally done through the printer's Menu on the printer's buttons.
If your are using a network IP range 192.168.0.*** that your wireless router issues automatically then select a fixed IP address on your printer above the number of computers that is installed on your network. (ie if you have 10 computers the make the printer's fixed IP address say 192.168.0.30) so the wireless router cannot issue a conflicting IP address.
When you install the printer driver on each computer then go to the Printer Properties - Port tab - click Add Port - IP port and enter the printer's fixed IP address and printer name.
Do a test print to check if your computer connects to the network printer.
Oct 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
Can't connect bluray to WBR1310
If the IP address is fixed in the BlueRay player, I would reboot the router or modem, which will reassign IP addresses. If one is in use, such as the Blue-Ray, whichever device is currently using it will get assigned a new IP address, assuming it too is not a fixed IP address.
Oct 27, 2017 | D-Link WBR1310 Wireless Router
I have a message that say Ip address conflict, what can I do
I have wildblue and my connection will not consistently connect . It freezes up the computer running xp wireless router is WNR854T
With wireless connections, there are at times brief disconnects. If you set your computer's ip address to a fixed value, this may help the problem. With a DHCP connection (not fixed) you could be getting a different address after one of the temporary disconnects causing the hang. Go to control panel, network connections, properties, then scroll down the window to the tcp/ip line , highlight it, then click the properties button. In the properties, click the use ip address button, enter a fixed ip address. If you are using a standard home address system, use 192.168.1.10 (if you have more than one computer, make sure each address is unique). subnet mask is 255.255.255.0, gateway is your router ip address, typically 192.168.1.1. Check your router information to be sure. You can use your router ip for the DNS server ip. If that does not work, check the DNS address provided in your router settings. Save all the settings.
See how that works, if it works, please leave feedback.
Good Luck
Feb 13, 2010 | Computers & Internet
Blocking email
The ISP provider changed our IP address when we reset the modem.(even though they swear it was a fixed IP) The mailguard delivery address is fixed so the redirected mail from mailgaurd no longer had a valid address for delivery.
You can fix this by correcting the mailguard delivery IP address (phone them in business hours) or by providing Mailguard with a name address instead of an IP address .
Simple but frustrating until you think of checking to see if the IP addresses of your server and mailguard match
Jun 15, 2008 | Cyberguard SG300 (00852503000366) Firewall
Ps3 ip address problem
when tring to test connection it says ip address failed
Feb 13, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
116 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
