Question about Ryobi Circular Saw W/Dual Laser
My saw is just making a clicking noise when i depress the lock off button and trigger switch,can't get it to work.
  • David Ford
    David Ford May 11, 2010
    what is the brand and model number and I will try and find a manual for you and come up with some suggestions. One thing to look at is the spindle lock stuck or can you turn the blade freely by hand. Let me know.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
You either have a break in the cord or the switch is open (broken electrical circuit). Sometimes the cord will get pinched or wound and the wires inside will break. A quick way to test a cord is to crimp the cord in your hand the entire length from the plug to the handle while holding the switch in the on position. If there is a break somewhere crimping the cord should make contact for a couple of seconds and you will get some power to the saw. The best way to check is to use a multi meter to check the continuity of the cord. You will have to remove the switch from the housing and use your meter on the cord. Set your meter to the ohms function and test the continuity of the load and line wires. (Touch one lead of the meter to the blade and the other to the corresponding wire that goes into the switch. Hint the polarized blade side - wide side- is the white wire and the smaller blade is the black wire.) If you have continuity through the wire you can check the switch next. Locate where the cord wires go into the switch and the other two wires that come out. Test at these two points while depressing the switch. If you have continuity in the switch and the cord you need to check the carbon brushes to see if they are worn or broken. If you need any assistance please post back and I will help.
Posted on Oct 01, 2009
LS1013 Sliding Arm Saw. Why doesn't it turn on when trigger is depressed?
The trigger may have simply failed. Usually failure occurs at the least convenient time or circumstance.
Sep 05, 2015 | Makita Saws
Why doesn't the spindle lock button depress?
no it will not stay depressed
simple reason
if it stayed depressed then most people would forget that fact and power on thereby destroying the unit
Jun 27, 2015 | Ryobi P501 18 Volt 5 1/2" Circular Saw...
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
I am using a this jigsaw and the motor keeps running whether i am holding down the button or not is this normal??
unless the trigger lock is depressed it is NOT normal and potentially dangerous if you lift it up and could possibly cut you. The switch has a problem and would need to be replaced.
Apr 09, 2012 | Bosch Saws
What is the security lock on a Dewalt 24v reciprocating saw? Does it affect the use of it? I want to purchase one but the security lock doesn't work. Thanks for your help.
The trigger lock on a recip saw is a safety device that is there so the trigger switch will not work unless the lock is pressed first. If the lock doesn't work the saw will still work properly, it just isn't as safe. Anything that touches the trigger switch, from accidental contact by yourself or things you're working on to little children, can make the saw start up.
Mar 18, 2011 | Garden
Saw stopped working during a job How to troublwshoot a trigger switch on circular saw
when you pull the trigger switch it should "click" when engaged.. if you don't hear a "click" then you have to replace the trigger.... If it does click then it could be brushes, or a short in the cord.
Jun 18, 2010 | Craftsman Saws
Dewalt dw705 miter trigger won't pull/depress
DeWALT DW705 TYPE 8 12 Inch Miter Saw Parts Sounds like a bad switch, Since you don't have any money it go ahead a replce it. Good Luck
Sep 07, 2017 | Dewalt Saws
Can not unlock saw
there is a safety button[usually by thumb area when u grab handle ] on most saws that has to be pressed as well as the switch when using circular saws
Jan 18, 2010 | Saws
How do you remove the safety button on a sears electric chain saw switch, so that I can replace the switch?
On most electric saws,you have a lock out button that you need to push in prior to depressing trigger.If this is the case on your model, the lock out button can be removed by pulling directly out of saw housing.It takes a little force but it does snap out
Nov 12, 2009 | Garden
Hi, need to use drop saw. Have used many times, however husband usually around. He has now passed away, and I know this may sound ridiculous, but have plugged in and can't find power switch or catch to...
If this is a Makita Mitre saw the switch requires 2 operations to engage. First you should see a round button on handle, you need to depress the button and then pull the trigger. I would recommend doing this with the tool unplugged first so you get the feel for it. Second the release button is on the right hand side of the saw, what you need to do is push down on the saw head some and PULL out on the round pin to release. I would recommend also that you go to Makitatools.com and type in your model number and download a owners manual so you can see exactly how to use the tool. Let me know if you need any more help please.
Jan 08, 2009 | Makita 10" Miter Saw LS1030N
Ryobi Circular Saw W/Dual Laser Logo
267 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
