Question about HP Officejet 5610 All-In-One InkJet Printer
I can't print a pdf file. While printing the file a msg pop up as: unable to strat print job, is printer available?... and when I click ok nothing is happaned.
2 Suggested Answers
rentpal
  • 80 Answers
SOURCE: I can't print a pdf file with officejet hp5600
hi,
please check if the print spool service is working or not.( start - run - services.msc)
Posted on Sep 27, 2009
The computer shows it is connected to the printer, the job is pending but nothing happens? Can you help please?
I think there has maltiple print job in your printer.
To solve this problem :
click strat manu>click printer and fax>duble click printer icon> delite all print job
Thank you
Mar 02, 2011 | Lexmark X4530 InkJet Printer
I want to print pdf files but the mesage "unable to start print job. Is printer available?" apeares. i have adobe acrobat 8 . i can print this document with another computer with the same adobe...
go to start...
control panel...
printers and hardware (or something like that where your printer is listed.)
Double click on your printer and the document queue window opens
Now go to file, right click and check if the 'use printer offline' mode is checked. Uncheck that and you should be good to go.
Otherwise there could be a problem in the USB port of that computer. Try and connect the printer directly to USB and not through an extension.
Jul 24, 2010 | Adobe Computers & Internet
My printer won't print ADOBE files, but prints all word documents
I believe you are misunderstanding what you're "telling" the computer to do. You are telling the computer (I assume in Microsoft Word, but perhaps elsewhere) to generate an electronic document in PDF format. (I believe PDF stands for Portable Document Format)
It uses a printing metaphor because like a paper copy, the PDF file is designed for people to read, not edit the document you have created. Also, some PDF-making software methods involve pretending to be a printer, which allows the user to make a PDF file in any program that would normally only output your work to a printer.
Most people, when wanting to print a PDF document onto paper, open it with Adobe's Acrobat Reader (which is free software) and print the document from there. For sharing a document that you want no changes to, this is a superior option to sending people an MS Word .doc (or .docx) file, which does not have its information "locked" onto virtual pages in the file.
I hope this helped!
Jan 18, 2010 | HP DeskJet F380 All-In-One Printer
I can't print pdf files from the internet, I have to "save as"1st
Sometimes the file name assigned to a pdf is not compatible with our printer's memory. For example, if the file name includes brackets [ ] or other punctuation, or is very long, the printer won't recognize it. One print job that stalls will hold up the entire print queue, so delete your job from the queue.
First, look at the file name displayed in the print server's list of print jobs. The same file name also appears in the top blue bar of your Acrobat pdf display. Are there brackets, per cent signs, or other punctuation marks in the file name?
Dec 28, 2009 | Microsoft Office Home and Student 2007...
hi,
Sep 27, 2009 | HP Officejet 5610 All-In-One InkJet...
"unable to print" msg
you could try going into control panel clicking on your printer then click on printer top left and cancel all documents
Jul 30, 2009 | Brother MFC-5440CN All-In-One InkJet...
Msg saying unable to start print job. is printer
Uninstall the Adobe PDF viewer and then reinstall it as the printer is respondingto other print commands,so its an issue with the s/w you are using.
Jun 11, 2009 | HP PSC 1410v All-in-One Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Sep 23, 2008 | HP LaserJet 4 plus Printer
Msg 'unable to start print job, is printer available'
A customer called me with the same msg. Let me explain first what the problem was..they had a Graphic PDF that on the HD was 20 MB but when extracted was well over 200 MB..first I had thought the pdf was exeeding the Printers memory but after testing it was not. The customer was printing the document using adobe PRO I had him print the document in reader 8.1 and made sure the print as image under advanced was selected and the document printed..
Aug 09, 2008 | HP PSC 1410v All-in-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
