Question about Compaq Armada M700 Notebook
Power my compaq m700 boots up fine i start to work but after a few minutes it turns itself off it is the same on battery or a c power
  • 4,402 Answers
Are you sure your get ac power, im thinking you ac plug in the computer is loose.
Posted on Dec 17, 2007
I have a Compaq M700 lap top. power failure , Won't boot up ?
You need to find out if the power supply was damaged, it would have been the first to take a hit, remove the main battery to see if it will boot because a bad one will load the system down in some cases. One trick that might work, unplug power supply from laptop and remove main battery, now press and hold power for 2 minutes to drain off residual voltage and reset the processor, finally install everything back and power up.
May 03, 2012 | Compaq ARMADA M700 PIII500 MHZ LAPTOP...
Its not booting or when it does,after 2-3 minutes of work it freezes.sometimes works just fine an hour or two.nowadays it wont even start.
Based on the information provided, it sounds like a heat-related hardware issue. Can you hear the CPU fan spinning when it's turned on? If not, that's the place to start...
Feb 28, 2011 | Compaq Armada M700 Notebook
M700 won't work on battery anymore
This could still be a bad battery, even though the indicators and the machine are telling you that it's charging. Laptop batteries are a bit more complicated than regular batteries, they have built in fail safes in order to keep from damaging the machine if the battery malfunctions. If a fail safe has engaged due to a malfunction this could cause the problem. Start by trying a new battery. If a new battery doesn't cure it, then the problem may lie with the power management system on the motherboard.
Jul 20, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
My compaq armada m700
Try to find a boot CD .Put that CD and try to start you computer and see it work or not.Incase it doesn't ,that mean you have a bad CDROM,you've to replace with the new one then.
Apr 28, 2008 | Compaq Armada M700 Notebook
Laptop shuts down
check the timer setting and set it to always on
Mar 18, 2008 | Compaq Armada M700 Notebook
Battery for Compac Armada M700
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Feb 12, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Oct 30, 2006 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
