Question about Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018
How do you Replace string on the trimmer head spool
Lost my Manual in a move and can not figure out hoe to refill the string spool.
  • 881 Answers
Take the spool off and turn it up side down take out the centre and wind the left side 6 times to the left and the right side 6 turns to the right then put the ends through the holes and refit to stud and screw on butter fly nut...
Dont try winding them both the same way as when you try to get more out 1 side will come out and the other will go inside so you will be back were you started
Posted on Sep 27, 2009
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a Echo Gas trimmer SRM-210 Rapid feeder dual line. I need to know how to remove the entire drum for the string spool? NOT how to re-string but how to replace entire head/spool, as if I was going to...
In your manual under section 12: Line Head Installation. You will do the opposite of what it says here. The key is to LOCK the gear drive so the flex-drive shaft won't turn WHEN you are removing the trimmer head. They use a special tool (maybe you have it). But a small-shafted Phillips screwdriver or the like can be put in the drive hole to lock the gearing up as well. Look for the hole in the upper plate and align with the notch in the drive housing and grasping the entire string head unit, remove it. Here is your manual, see Section 12
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
Jul 17, 2011 | Echo Rapid Loader, Trimmer Head
I have a Ryobi 700r gas string trimmer and I do not have the manual for it. How do you get the trimmer head off to replace the string?
Remove the large spool bolt on the bottom. Remove the spool. Inside you will find a friction nut. Carefully pry it up around each side with a small flat screwdriver. If it gets damaged then it will need to be replaced (hardware stores will have this). Once it's off, you should be able to slide the remainder of the plastic spool off.
Sep 13, 2010 | Black & Decker 8 Inch 12 Volt Cordless...
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
I can't figure out how to replace my spool
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and
pulling away from unit. Replace empty spool with new full one or wind on aftermarket
string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
MANUAL:
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
PARTS:
http://www.ereplacementparts.com/black-and-decker-grass-trimmer-parts-c-4167_9518.html
Mar 14, 2010 | Black & Decker 14" Grass Hog Xp...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018 Logo
334 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
