Question about Mitsubishi WT-42311 42" Rear Projection Television
2002 Mitsubishi VS50111
My TV is doing the exact same thing & the model number mentioned here is on my Owner's Guide. Can I do the same to repair my tv? I also got a 22 error code when I pressed input & menu
    President:
  • 4,402 Answers
Convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 17, 2007
Does my vizio e series a-1 Tv have pip?
Hi
You do not give your exact model number so I couldn't look at the specific manual/users guide. I did look at one of the e-series guides and there was no mention of PIP (I presumed Picture in Picture and searched for several variations with no success). However if you go to the web page below, you will be able to find your exact model and then download the precise user guide and check it for PIP.
VIZIO Product Support and Services VIZIO
Good Luck
Nov 13, 2014 | Televison & Video
Need codes for mitsubishi tv
I do not understand if Mitsubishi remote why it needs to be programmed for a Mitsubishi set but Google the model of the remote for a owner manual and a possible list of codes for whatever you are trying to program it for.
I exact replacement for a Mitsubishi TV you should only have to put batteries in it and select TV button on the remote.
Dec 18, 2012 | Mitsubishi Remote Control CK32308...
With some dvds picture is split screen showing the picture on both halves of tv screen, how do I make this a single picture on whole screen?
HI,
Check on thing Go to the SETUP Menu and check is there is any System settings (colour system) on both DVD and TV . Try all the settings available in the colour system setting. As you didn't mentioned anything about Brand and model number of the player or tv. Its not possible to give you the exact solution.
Ajin
Jul 25, 2012 | Audio Players & Recorders
I need the code for unlock my tv, please help me with that.
I think you mean the parental control lock. You can bypass this added feature, or disable it completely by following the instructions in the appendix (page 84) of the owners manual.
You can find the manual by clicking the link below
Download Mitsubishi CS 31305 Owner Manual
(the guide is correct for your model number- its a catchall for other similar models)
Hope that helps
Dec 06, 2009 | Mitsubishi CS-31205 TV
Mitsubishi tv model #VS50111 The TV stopped
most of the time it is the vertical output ic. suggest local service center. sorry
Nov 12, 2009 | Televison & Video
How do i turn off v-chip on my mitsubishi tv model # is WD62327
Let me know brand and model number of your TV to look for its Instruction Manual for you.
Dec 05, 2008 | Mitsubishi WD62327 TV
Samsung rear projection 50ins
Seems convergence problem in TV and please mention exact model number of TV to guide you further.
Nov 03, 2008 | Samsung Televison & Video
Mitsubishi Projector DLP TV
This problem is covered under the mitsubishi extended warranty for the 73" dlp. I would try contacting them to see if they will cover it. Not sure how they will handel it because you bought it second hand. If mitsubishi will not cover the repair the first thing you need to try is removing and re-seating the dvi cable between the o-block and the chassis inside the tv. mitsu claims this to solve the problem sometimes but i myself have never had it work. the only other thing to do is to replace the optical block assy. this is an expensive part. let me know if you have more questions!
Tim Nolan
Sep 24, 2008 | Televison & Video
Mitsubishi vs50111
Is the TV about 2 yrs old. Either the bulb is burnt out or there are capacitors in thr power supply that need to be replaced.
May 26, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
