Question about Garden
How do gas lines go back on trimmer - Garden
2 Suggested Answers
  • 279 Answers
SOURCE: gas line cracked and nipple fell back into tank
Empty the tank by dumping into a can or something. Shake the trimmer around until the "nipple" falls out. Get a replacement fuel line and follow their instructions. When yoou put the tube back into the tank, have something that you can guide the line through the hole with. I used a small hex wrench. If you cut the tip of the tube at a sharp taper, it will be much easier to start through the hole. You might think of replacing the return line as well. You should not have to remove the tank if you expose the carb and remove the air filter...Good luck...Lee
Posted on Aug 03, 2009
How to change my gas line on a 17 inch 25cc gas weedwacker trimmer/edger
basically this is a very simple thing to do as long as you have purchased the correct size of hose. Before removing the fuel line from the tank remove it from the carburetor. then you need a small bent wire or something like it to fish the filter out of the fuel tank. When you have that done you need to remove the filter and just pull the fuel line out. When you install the new line in the tank you need to snip the new fuel hose at an angle to help in the ease of re installing it. Once you get it started you can either reach into the tank with needle nose pliers and pinch it so you can pull it back into the tank. Or you can just twist it in a circular motion until it feeds itself into the tank. The rest is common sense. Install the fuel line filter and put it back into the tank then suck a little gas up the line so the carburetor don't have to do it. that'll prime the line and make it easier for the trimmer to start.
Jun 29, 2014 | Craftsman 25cc Gas Line Trimmer
My stihl grass trimmer filter came off gas line in gas tank and I can not retrieve gas line.
Usa a bent coat hanger or wire to hook the fuel line out the top of the filler cap. It will stretch enough for you to push the filter back on.
Apr 12, 2013 | Stihl Garden
How do i fix my flooded TB32 EC troy bilt weed eater?
be sure fuel filter is on the primary fuel line in the tank.check primer bulb and fuel lines.also check fuel tank cap.vented cap may be stopped up
Sep 10, 2012 | M T D Southwest Inc Troy-Bilt TB32EC...
Ineed a daigram of the fuel line system lines deteriated and don't know to put back together
Get the model number off of the trimmer and go to this website: www.searspartsdirect.com You will be able to look up a schematic for your trimmer which will help.
Aug 12, 2011 | Craftsman Convertible 25cc. Gas Line...
Need to know how to wind trimmer line on trimmer
depends on the trimmer, all heads are different. However, the majority of trimmers are wound as follows:
1. pop the top cover off the head, pull the spool out. It will be either single or double lined, they will be wound counter clock wise.
2. the end of each line goes out each of the seperate holes
3. slide spool back on and replace cover
www.ButlerPower.com
Sep 04, 2010 | Husqvarna 28cc Gas Line Trimmer
The 2 lines from the gas tank 1 goes to the filter and the other goes where?
the small line goes to theclunk ( filter ) and the large line is just a return line dumps thefuel back in the tank.. good luck
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
My troy-bilt TB425CS gas string trimmer gas lines have gone away. In replacing those lines how far into the tank do they go?
far enough so that you can reach through filler cap and pull the line out to attatch fuel filter.
then you can pull it back in and let it rest on the bottom of the tank
Aug 14, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Gas line cracked and nipple fell back into tank ..how do I remove gas tank to replace gas line and nipple????..ryobi 725r trimmer
Aug 02, 2009 | Ryobi Garden
Fuel Lines leak where they pass through opening into tank
i had the same problem with my trimmer. you could replace the fuel line but if you don't want to hassle with fishing it thru the hole i suggest going to homelite.com and ordering the gas tank. it only cost me $18 with shipping and came with everything (tank, lines-with fuel filter, and gas cap). all you need to do is take out the 4 bolts on back of trimmer and the 2 top bolts holding the housing together. be careful not to nick any gaskets especially the one behind the 4 bolts. this is the crankcase gasket. also don't get anything in the crankcase that will score it as this will ruin the trimmer. also there are 3 spacer gaskets that go in the holes in the fuel tank and i believe a plastic heat shield between the gas tank and the bottom of the trimmer. you will see this when you take the tank off. just be careful and be sure all the bolts get tightend up (especially the 4 on the back as this is the back side of the crankcase). it only took me 15 min to replace it and the trimmer runs great. all the above info is if you have a trimmer with the gas tank on bottom. if the tank and gas cap are on top hopefully someone else will be able to help.
good luck
Jun 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
