Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
GE Upright Freezer is not freezing
I have a GE upright freezer. Model FUF 20DACRWH SERIAL # MT177996, MANUFACTURED 7/98.
During the power shut off last December. It quit freezing. The fan inside, works, so does the internal light. But not cold.
What could be the possible causes and solutions?
  • jbschwartz Jul 21, 2008
    Have GE Upright Freezer FUF 20DACRWH.
    Temp has been rising over time. Now, it is 40F.  Fan is running. Light is on. Compressor is HOT.
  • 89 Answers
It is very common for the "relays" to go out on the compressor. The relays are mounted on the left side of the compressor. You need to find an "Appliance Parts Store" and buy an "RO-41". (this is a relay) it cost no more than 10 bucks. Go home with your new bought relay and pull your refrigerator out from the wall. Don't forget to unplug it! Take off the rectangle card board cover off the bottom of the refrigerator "in back"... More than likely 1/4 nut driver. Now look for the compressor--"The Roundish black thing the size of a basketball". Next, you will see a box looking thing (black, white) mounted on the side of the compressor with 2 wires going to it. Next take it off the side of the compressor. It just pulls straight off! Sometime though it may be held in place by a little clip. Now read the instructions with the RO-41(inside cover). You will end up cutting the old relays off. Take the two wires that went to it and wire them into the relay(follow the instructions w/relay) then other wires on relay plug right into the compressor! AND THATS IT! It sounds hard but aint... goodluck!!!
Posted on Dec 17, 2007
My GE FUF 14DMDRWH freezer is having the problem of not being freezing at the upper 2/3, but is freezing at lower 1/3.
check the freezer fan. sounds like its stalled, or that the ref is not defrosting properly ................ hope this helped............. ken
Sep 30, 2014 | Refrigerators
How can i convert freezer to refrigerator
Usually this can be achieved by changing the REFRIGERANT GAS used AND vice-versa [ie fridge-freezer or freezer-fridge]. IF your unit has twin compressors [as most modern combo-units do] your local Refrigeration Engineer should be able to do this for you. With modern compressors and Environmental Regulations this is NOT a DIY job ... ok [as used refrigerant gas must be safely removed and disposed of as directed by local Environmental Laws].
Sep 21, 2014 | Refrigerators
Fuf 14
If the compressor is running yet the suction (larger pipe) on the compressor is not cold, or if it is frozen, you probably have a refrigerant leak and need refrigerant.
Jun 11, 2014 | GE Freezers
Freezer not freezing
If you can hear the motor running it could be the thermostat that has gone or if there is no noise at all it could be the motor that has died, a good easy fix ( sometimes works ) is to turn the freezer off leave it for 24 hours with no power then try turning it on again.
Apr 22, 2012 | Kenmore Freezer 20.6 cu. ft. Upright...
I want to know how long the warranty is for GE Model FUF 17DPHRWH, Serial Number DL177038. Thanks. My phone number is 806.335.3745
The warranty offered by GE on the FUF17DPHRWH is one year for parts and labor from the date of purchase if the unit fails due to a defect in materials or workmanship. If you pay for the GE Service Protection Plus, you will get longer coverage. (However, I've found that for most appliances, you would be better off putting the annual fee for the service in a savings account. Then when the appliance fails, use the money in the savings account to repair or replace the applaince.)
The manual is available here: . If this direct link doesn't work, start at and enter the model number. Then click Submit.
I hope this helps.
(I have no way of looking up GE Service Protection plans.)
May 20, 2011 | GE FUF17SVRWW Upright Freezer
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
206 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
