Question about Vtech Cordless 6041 Phone
The caller ID does not show the correct day and time. The day and time is correct in the phone setup program
  • Vtech Master
  • 2,460 Answers
When I first switched to Packet 8 (now 8x8) I found out that my automatic time set would suddenly shift to 3 hours difference. The problem became difficult to find, because it was only one of 3 lines on my phone system. I came to find out that it was because the first call on my system after 2AM set the system time, and if it wasn't on the 8x8 line, it didn't change the time.
A quick call to 8x8 and they gave me the password to log into the 8x8 box to set the time zone to Eastern time.
Check with your dial tone provider or their web site and see if you can do the same with your unit.
Carl
Posted on Sep 27, 2009
CORDLESSGURU
  • 106 Answers
SOURCE: Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Posted on Feb 10, 2008
SOURCE: Philips CD240 cordless phone
need manual for philips cordless phone CD 240
thank you
degs
Posted on Aug 29, 2008
SOURCE: Uniden CXA15198 not showing caller id
uniden model dx18560 not showing caller id
Posted on Dec 13, 2008
SOURCE: Uniden Power Max 5.8
Try deleting a few entries on your phonebook. One possible reason is that your phone book memory on this perticular unit is full and the same memory is used for CID display. Hope this will work!
Posted on Feb 17, 2009
  • 32 Answers
SOURCE: Talkswitch caller ID from outside calls not working
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Posted on Jan 21, 2010
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
Cannot program, menu stuck on Spanish, cannot access main menu from mute/ok button
I know this should be a MUCH more techie answer, but have you tried just asking a nearby Mexican to help you? Just a thought.....
You say you cannot get to the menu from the mute/ok button?
What happens instead?
FROM DA BOOOK looks pretty clear to me.
Handset Setup
1. Make sure your phone is OFF (not in TALK mode).
2. Press the mute/menu OK button to go to the main menu.
3. Press CALLER ID-VOLUME ( 6 or 5) button to scroll to HANDSET SETUP.
4. Press mute/menu OK button to confirm and you may program the following items: Language, Handset Name, Ringer Tone, Ringer Volume, VIP Melody, Key Tone, Set Day/Time, Equalizer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
NOTE: During programming, you may press the END/cancel button at any time to exit the sub-menu and return to the menu.
Language
From the Handset Setup Menu:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the SET LANGUAGE sub-menu.
2. Press mute/menu OK button to enter the menu. SET LANGUAGE 1ENG 2FRA 3ESP shows in the display.
3. Use the touch tone pad on the handset to select 1ENG, 2FRA, 3ESP, or use the CALLER ID-VOLUME ( 6 or 5) button to scroll to the desired language. English is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the selected language shows in the display.
Apr 29, 2009 | Uniden Cordless Phone
No Caller ID on display
To set up call id you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
that should do it providing you have caller id service though your local telco provider.
Mar 25, 2009 | NorStar T7316E Corded Phone
I have a 4 line NEC Dterm 80 phone. How do I recall the past
depends on the type pf system. Do you have a coib installed in the system? Is caller id setup or programmed? If there is no mif card in the switch you cannot save caller id info. It only shows up when the phone rings and while on the call. There should be a directory key that you can price to scroll through the numbers if everything above is correct. ldtsnj.com
Dec 31, 2008 | NEC DTU 8D-2 Corded Phone
How to setup caller id?
Have your tech look again. A keyword search of CALLER ID in the pdf should explain it all, especially page 158 of a 6.1 CICS manual.
You need 2 things to make it work. One is that your phone has to be ringing. Two is that Under Telco Features in programming for your set is a CALLER ID set which is No by default.
Of course, FEAT 811/812 will work after the fact.
Carl
Nov 13, 2008 | NorStar Meridian M7310 Phone
Caller ID
just go in the settings of ur phone and then phone setting or in contact setting
Jun 04, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Caller ID shows 0/0 12:00AM for date
you need to reset the global settings in menu handset setup
Apr 12, 2008 | Uniden Cordless Phone
Caller ID
press feature 811 then touch the ringing line and it will display the caler info.
Mar 14, 2008 | NorStar T7316E Corded Phone
Caller ID
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Caller id
Unfortunately just adding caller ID to your phone line will not work with many business phone systems, especially older systems.
You can have this phone on one of several different Toshiba phone systems. The system must have caller ID equipment installed and programmed correctly for caller ID information to be shown on your phone's display.
Caller ID information is transmitted between the first and second ring. With business phone systems the system itself needs to collect this information and then pass it along to any phones that are programmed to ring at any given time.
Oct 26, 2007 | Toshiba DKT-2010 Corded Phone
Vtech Cordless 6041 Phone Logo
154 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
