Question about RCA RC10.4IRF Car Monitor
Wheels begin to spin as soon as battery is put in car.
    Problem Solver:
  • 11 Answers
Lower throttle
Posted on Sep 27, 2009
How do I fix the remote on the RC Thunder Tumbler RC Car to prevent the tire from spinning as soon as the remote control is turned on?
Use the throttle trim control to try and adjust this unwanted throttle application out. Refer to the user manual on how to trim the remote functions
Oct 17, 2016 | RC Thunder Tumbler Rc Car
Hi i have a julin fighter scooter 50cc this morning the drive belt broke replaced the drive belt got the bike to start and it revs high when on the stand but when we kick it off the stand it will only tick...
Hi, Anonymous and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
Good luck and have a wonderful day.
Jul 03, 2017 | Motorcycles
4 wheel drive will not disengage on 1987 suzuki
Date: 06/19/87ST-022 SUBJECT: TRANSFER CASE BIND-UP
Transfer case bind-up is a phenomenon that can occur if a 4WD vehicle is driven on dry pavement in 4WD. The vehicle begins to slow as if the brakes are being applied and the transfer case lever may bind. The condition is caused by the front and rear wheels turning at different speeds because of unequal tire pressures or turning. The transfer case inner gears and components absorb the unequal rate of wheel rotation and begin to bind until the vehicle and transfer case lever become immobile. To relieve this situation, place the transmission in neutral, and jack up each end of the vehicle, one at a time, and allow the wheels to spin freely. Be sure to chock the wheels that are not raised to secure the vehicle from rolling in either direction. It may be necessary to rock the wheels back and forth when they are raised to unload the bound mechanisms in the transfer case. This procedure will allow all driveline pressures to be relieved and the vehicle can now be operated normally.
Aug 07, 2012 | Suzuki Samurai Cars & Trucks
I have a simpson Ezi loader dryer. It has stoppes spinning and I am getting a buzzing from it. The belt is fine. When I run the dryer with out the belt attached the motor spins fine. As soon as I connect...
Something is jamming where the blower wheel is. You sound pretty mechanically inclined and know your way around the machine enough to skip the beginning steps. The blower wheel connects to the motor shaft and depending on the model may or may not be covered when the machine is taken apart. Once you locate it I guarantee you'll find something binding it up.
Apr 28, 2012 | Washing Machines
My 4 wheel drive isn't working. why are my tires spinning on the littlest patch of ice?
Hi Correia,
Having four wheel drive built onto a vehicle gives traction through all four wheels, meaning that if one of the four wheels looses traction all the driving motion is directed through that spinning wheel. When driving on snow, ice or mud, gently does it all the time! Gentle acceleration and slow down using gentle gear changes. Use the brakes as little as possible. Remember if you lock up the brakes and the vehicle begins to slide you'll have no control at all! Traction control is entirely different than four wheel drive. Traction control will control any wheel which begins to slip and thereby keep you in control.
Regards Johngee10
Feb 11, 2011 | 1997 GMC Sierra
A roaring in left back wheel
sounds like a wheel bearing put it on a lift and spin the wheel
Sep 29, 2009 | 2005 Honda Accord
How to change oil filter for honda odessey 2004 mini van. Please help
I change mine on level ground or driveway. I don't jack up the car. Before beginning, turn your front wheels all the way to the right. Put a pan under the filter area. The filter is on the right side of the engine and can be accessed by reaching into the right wheel well (with the right front wheel already turned to the right.) You may need a strap wrench or an oil filter wrench to loosen the filter. Once you get it loose, you can spin it off by hand. Expect about 1/4 cup of oil to spill all over the filter and drip off into the drain pan. Clean up the mess with paper towels. Wet the gasket of the new filter with clean oil and spin it on. After the filter gasket makes contact with its seat, hand tighten the new filter one full turn.
May 16, 2009 | 2004 Honda Odyssey
Drum spins without a load but won't witha load
It sounds like a motor problem. It puts the motor under maximum load, when dryer is full and just trying to begin to spin.
There are 2 different types of motors, those with capacitor start and those with inbuilt centrifugal switch.
What is your make and model of dryer please? Or if you take off the back panel, can you see a small plastic cylinder, about 2 inches long, with 2 wires to it? Will be mounted close to the motor, but seperate from it.
If it has one, try replacing the capacitor. ( I have about half dozen good secondhand ones lying around at my place (Brisbane))
Good luck, let me know how it goes.
May 06, 2009 | Dryers
Spinning wheel of death on word doc
looks like OS problem
you might have to replace HD
either youve bumped it a bit, or the files are currupted, i doubt you have a virus but thats another issue.
try reinstalling the OS
hold power button til it shut off, then put in OS CD hold the "C" key down to boot from CD
then reinstall Operating System
Aug 16, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
RCA RC10.4IRF Car Monitor Logo
20 people viewed this question
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeff Turcotte
Jeff Turcotte
L Pfaff
L Pfaff
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
