GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Sep 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Defrost timer comes on automatically and no other keys are working, to reset we have to open the door and press all the keys
  • renecon Sep 27, 2009
    ON MODEL JVM290
Terence Fourie
Level 3:
  • GE Master 909 Answers
  • Posted on Sep 27, 2009
Terence Fourie
GE Master
Level 3:
Answers
909
Questions
0
Helped
375324
Points
2542
Sad to say, that comes under a faulty board scenario.Normally if it is the keypad, only some some selections are not possible. Quote model to spares supplier to get correct board.Please beware of voltages neat capacitor. Nasty stuff.
2answers
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
If I set the timer by error wrong I am not able to change the time. Is there any way to handle that?
All you need to do is to reset . you can use the stop key to press for while or open the door. If not remove power or switch off main power for a minute.
4helpful
FRIDGE button is set on 3, red light flashes, air system works but it is not cool for at least 1 hour, Freezer set on 4 S and works.
Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermistor and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it. Then make sure all the vents are clear and not being blocked by food cartons. One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem
If you find this helpful, a vote with the thumbs up would be appreciated for the free advice
Why is my refrigerator not working properly? well , since I got it I have problems because it never seems to get cold or work properly. I think it might be cause it is digital.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
3helpful
3answers
My refrigerator stopped working and will not come back on. It is a Jenn-Air Side by side purchased 4 years ago.
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
LMV1630st sparked and then stopped working.
http://www.fixya.com/support/t886241-power_turns_off
please use this link to view another servicemans explanaton of what your problem is and hopw to address. In essence, you should ALWAYs press the stop button before opening the door... Hope this helps you...
2answers
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
