Question about SanDisk Sansa E280 MP3 Player
Sansa 280e internal memory change to e260 internal memory
U guys know how to setup to factory restored, or change it back to e280v2 i appreciate any solutions. thank u
  • 8,596 Answers
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Posted on Mar 18, 2008
My sansa e260's recovery mode doesnt work..it just stops in "USB Cable connected"...and when i plug it in the pc...the pc says "Unrecognized USB Device"..Help...The player works well but i cannot add new...
Try this:
1: Open "My computer".
2: Connect your unit to your computer
3: Right click on the MP3 icon
4: Click on "format"
5: Choose "quick format"
Keep in mind, this will fully restore your unit back to factory fresh, and you will lose all your files.
May 25, 2010 | SanDisk Sansa e260 MP3 Player
I would like to reset my sandisk sansa e260 mp3
Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
Apr 09, 2009 | SanDisk Sansa e260 MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
Photos
if you plug your mp3 player in, it will open something saying what you would want to do with it. click open to view files, or something like that. click internal memory, then click photo. then, you can drag and drop your files onto it. if that doesn't work, get the sansa media converter.
Jul 28, 2008 | SanDisk Sansa e260 MP3 Player
How to restet my sansa e260
Menu - Settings --> Reset All
This option will reset all the Sansa e200 player’s settings back to
factory defaults.
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
Memory problem
I havent experianced anything like that but i would recomend you to Format the player IT WILL ERASE EVERYTHING THAT IS IN THE PLAYER. it will restore it to like factory new.
May 28, 2008 | SanDisk Sansa e260 MP3 Player
Storage
How it up to your computer with the usb cable, once recognized go to:
Start
Computer
Double Click on the Sansa
It will show memory usage and free of both internal memory and expansion card (if you have one in it)
If you double click on either one of the above it will show you the files
Mar 24, 2008 | SanDisk Sansa e260 MP3 Player
Restoring factory Sandisk Sansa e250R settings...
you might want to try right clicking on your mp3 icon while in rhapsody and clicking format device...
Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e260 stopped working after unsuccessful formatting
I have guys, I just spoke with the Sansa representative. Even if you have Windows Vista, you do not need a drive for e260 given that Vista carries that drivers for it. If you have tried the steps above, but you Sansa still did not format successfully after using the recoverty tool. This is what you do:
Set you Sansa e260 in recovery mode
- set it to hold
- hold rec
- connect to computer while you are holding rec
- device should be now in recovrey mode
- go to my computer
- go to the folder 16B format
- you will see a text file
- don't worry about
- add a new folder and name Sansa.fmt
- wait up to 2 minutes
- message on your device should say formatting
- wait a few minutes for formatting to take place
- stop the device by removing it safely using windows Safely device removal tool on bottom right corner of your screen
- disconneting your Sansa and you should see a message upgrade finished, Sansa has been restored or something like that
- Power your Sansa on, and Bwala!!! your Sansa is back to normal.
Good luck
Dante
Nov 27, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 4 gb mp3 player
You could reinstall the firmware (what makes the sansa work). Its pretty easy to do, no need of downloading/installig, its already all in the sansa. You just need a computer How do I restore the firmware Firstly, place the e260 in restore mode. To do this, follow these steps 1. Push the Hold button on top of the e260 to the right. 2. Hold in the record button 3. Press and release the Menu button 4. The device will now go into Restore Mode. If you have not already connected the USB cable to your PC, it will direct you to do so. 5. The root directory of the device will open up on the PC screen. Now drag and drop the two files Firmware into into the e260 root directory. You will find a copy of the two firmware files zipped up elsewhere on these forums 6. Push the Hold button on the e260 back to the left 7. Unplug the USB cable from the PC. The e260 will now reboot, writing the new firmware images to the correct location. 8. This process will have wiped all your music files. You will now need to re-synch.
Jun 28, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
103 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
