Question about Bosch WFMC 3200 Front Load Washer
Bosch Washer WFMC3200.
I open back and belt on the place. I can move belt and motor is moving with belt but when I powered on washer does not spin. There is an arrow code E21.
What is it?
  • voroni999 Sep 27, 2009
    My drum of the washer will not spin during cycle. If you turn it to a cycle and press start, it will fill, but the drum just sits there, then it will drain itself. Basically it will go through the motions of the cycle, except the drum never moves. It doesn't make any noise whatsoever, no hum from motor or anything, just silence.
    Door will lock and unlock.
    Took the rear cover off, belt is intact and all connections to and from motor are tight, nothing visibly wrong with it.
    I have no error codes on display either.
    I did spin test. When I put P:04 and pressed start - the door was locked, it start drain but the unit did not agitate and did not spin. There is an error code E20.
    What does it mean?
    Sergeant:
  • 228 Answers
Your motor brushes are worn out e20 is motor drive circuit error most likely brushes usually they last about 3 years
Posted on Nov 13, 2009
  • 41 Answers
First of all, start with you close the door,you put the set on and continue please
Posted on Sep 27, 2009
Washer Drum Not Moving- belt is fine
Brand new belt and no other symptoms; my bet is the motor brushes. You will have to remove the motor to check this. there are 2 holders for the spring-loaded brush. I am guessing they are worn down and just stopped touching. It's a "silent failure" with no real symptoms except is doesn't move.
May 26, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Drum won't move
take the back panel off make sure power is off and check if the belt has come off or broken and also check the pulley that spins belt is tight and if all that is ok then it sounds like the motor might need to be looked at
Jul 05, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
My Bosch washing machine has a drum that no longer turns. When the cycle reaches a point where the drum has to turn, I hear a series of clicks and the spin does not work at all. I took the back off and the...
Check you can move the drum freely by hand. 1. if its free - then check belt. 2. if it wines - check motor. 3. if does not move - you need to check for obstruction. hope this helps ....
Jan 07, 2011 | Bosch WFMC 3200 Front Load Washer
I have Bosch Nexxt Premium WFMC6400UC Front Load Washer. It noted a suds or pump blocked error. I was able to access the pump cleanout at the bottom of the washer and remove a small wire that was lodged....
Hello and welcome to fixya.
I`d suggest removing the back panel and inspecting if the belt has perhaps come off.
**Unplug the unit from the wall first**
If so, put the belt around the motor pulley and start it around the drum/drive pulley. As you hold it in place spin the large pulley and it should go back on, careful not to pinch your fingers...ouch :(
Let me know what you find out or if you require further assistance.
If this indeed solves the problem please take a second to rate my solution accordingly.
Thank you for choosing`"fixya" and good luck.
macmarkus :)
Jun 18, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Contact a Bosch technician. You may have to at least pay for a service call.
Sep 27, 2009 | Bosch WFMC 3200 Front Load Washer
Washer doesnt move
You don't say whether the timer seems to be working but if it does and it's just not agitating or spinning I would check the motor/drive belt. If you find that it is the belt the part is pretty inexpensive and it is relatively easy to replace. Good luck!
Aug 26, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfmc3200 will wash but will not spin or
hi, this is a drain pump motor issue. i would check the wires leading to the drain pump and the control board. make sure the pump wires are connected and the control board wires as well. if the wires are connected, this will rule out a communication problem and confirm pump failure.
You can also do a break point test with a multimeter on the control board to make sure the control board is working correctly.
Concerning the locked door(washer locked)**. if the door is locked, this may be a control fault. test the door lock mech for its operational value to confirm this as well.
May 14, 2009 | Bosch WFMC 3200 Front Load Washer
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFMC3200
Click on Bosch (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Plug off the wall, open up behind, you will see things.
Pl rate if helped.........
Jan 02, 2008 | Bosch WFMC 3200 Front Load Washer
WFMC 3200 WONT SPIN OR WASH
Open machine's rear panel and look for a broken belt and does the motor spins. Let me know with your results and we will see how could we assist you.
Aug 21, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
721 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
