Question about HP Office Equipment & Supplies
Paper jam - hp c4380
I am getting a paper jam on my c4380 printer, no paper is stuck
  • amratvishram Sep 27, 2009
    Hi, thanks for the above. Unfortunately this does not resolve the issue - any other suggestions
  • 58 Answers
Make sure that there is no paper stuck inside the paper, try cleaning the rollers, if the issue stil persit perform the below steps. Reset the All-in-One to the factory default settings by using these instructions: 1) Press ON and CANCEL buttons simultaneously 2) Display reads ?Enter Special Key Combo? 3) Press BLUE button, Green button and Grey button 4) Press Grey button continuously until "Resets Menu" is displayed. 5) Press Green button. 6) Press Grey button until "Semi full Reset" is displayed. 7) Press Green Button. This should resolve the issue.
Posted on Sep 27, 2009
  • Arun Kumar Sep 28, 2009
    your printers paper sensor might gone bad, the best option i suggest you is to service your printer.
Paper jammed when loading paper, don't know how to clear jam
Welcome to FixYa.
To clear the paper Jam, follow the steps below.
1. Remove all loose paper from the paper In tray.
2. Do not pull paper jam from under the front cover.
3. If there is more than one sheet stuck in the printer, remove the paper sheet at a time.
4. Make sure no scraps of paper are stuck in the printer.
5. If there is open the door at the back of the printer.
6. Pull the jammed paper out of the printer.
7. Check again to make sure no scraps of paper are stuck in the printer.
8. Close the back door.
9. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Mar 24, 2011 | HP Photosmart 2610xi All-In-One InkJet...
Continue to get clear carriage jam after opening door and clearing or moving the carriage in hp 4215xi
Click here for instructions on resolving carriage jams on the 4215xi. If you successfully complete these instructions and still have carriage jams, your printer likely needs service.
I am an HP employee. I do not represent HP on this site.
May 26, 2010 | HP OfficeJet 4215 All-In-One InkJet...
HP PSC 1610 - Keep getting paper jam error with no paper jam.
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper jam message no paper jam cartridge gets stuck HP 6310 all in one
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | HP Officejet 6310 All-In-One InkJet...
HP F4280 All in one Printer. Feed jammed (AVERY 8376 Ink Jet Business Cards); printer made noises, finally stopped; pulled paper backwards out of printer. Turned the printer on and the cartridges bang...
Well it's likely two cause in your case -
1.- It might be a misplaced actuator, check for instructions at:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&product=58057&dl...
2.- Check the power supply and its cable. It might be at the end of its life. Ideally, you should check the power supply under load at its limit. You may use a resistor rated for the load. It will be HOT, be careful. If you don't have it, might be more cumbersome, but you can use the printer as load, and make a test connector that allow you access to voltage terminals.
Good Luck!!
Thanks
Sep 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
C4380 HP Printer Sheet feeder jams
There is no fix an end-user can do. Calling a technician for service will cost you more than the printer is worth. Sorry
Jan 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
538 people viewed this question
Seeker5211
Seeker5211
