Question about Troy-Bilt Garden
Tiller will start but cuts off - Troy-Bilt Garden
  • 472 Answers
SOUNDS LIKE YOU HAVE A FULE PROBLEM
Posted on Oct 02, 2009
Engine cuts out when tiller arm lifted. Starts and ticks over fine. The tiller arm seems loose could this be the problem.
Sounds like the tiller arm has a Kill switch in the end to shut the motor off. If it does there are two black and yellow wires in there and they are shorting to ground or to each other when the arm is lifted. This would shut the motor off when the are is lifted. The black and yellow wire is the kill wire on most outboards. If it grounds out and the engine will not run.
Apr 19, 2015 | Boating
There is oil on the spark plug in my new honda mini tiller (less than a month old). What might have caused this, and how do I fix it? Tiller won't start
Id say if its that new I would return it .Otherwise was it ever stored upside down or was it laying on its side
Its unlikely its a air filter issue with that low of use but you may want to check there to see if the oil is being siphoned up thru the breather line in the air cleaner area. lf the engine had been ran dry initially then there could have been damage done to the cylinder walls and the oil could be passing what is left to the piston rings,if this is the cause the unit would need to be overhauled .
Apr 19, 2013 | Honda 25cc 4-cycle Mini Tiller
How do I start this tiller
Place yourself in front of the tiller, grab the handle firmly and pull
with all your force.The motor will turn and if fuel and the settings are ok
it will start and give it the necessary acceleration to cut your grass
Mar 29, 2013 | Garden
I have a murray FT6000X92A 6hp performance tiller...when clutch is engaged& going forward, tiller just wants to bounce on top of dirt, instead of digging in
Are your tines installed in the right direction. I have the same tiller in my arsenal and it cuts the soil just fine; even with sod in place. FYI!
Mar 04, 2011 | Garden
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
My mantis starts easily - but then dies. it sometimes doesn't even rotate. i can do about 3 seconds before it dies. help. what do i do?
The Carb is either cracked or needs to be rebuilt - OR - you might get luck and just blow it out with a professional dose of AIR from a larger compressor like used at mechanics shops.
Gary @ Fix Ya
Sep 05, 2010 | Mantis 2-Cycle Tiller
Ryobi Tiller, model RY60511A, will not start. Air
mine was a total pain. I yanked on the rope so many times, it flew out of the keeper,and when I replaced it I ran it UNDER the fuel tank cutting a slot in tank. I also blew out the primer bulb. AFTER the replacement tank I arrived, I discovered rolling the machine forward helped the flow to carb and did not require priming. Now I need to fix throttle cable. But all in all, a tough little machine.
Mar 27, 2010 | Ryobi Garden
My tiller only starts when I pore gas into the carberator air inlet. Then it surges for a couple of seconds and cuts off
IF THE TILLER HAS BEEN SITTING A WHILE I WOULD CLEAN THE CARBERATOR SOUNDS LIKE GUM BUILD UP. I HAVE HAD LUCK WITH DRAINING ALL THE OLD GAS AND DUMPING CARB CLEANER IN THE TANK WITH GAS AND KEEP TRYING TO START SOME TIMES THE CLEANER WILL DO ITS NJOB AND CLEAN THE GUM OUT OF THE PORTS IN THE CARB
Oct 12, 2009 | Troy-Bilt Pony Garden Tiller
Tiller starts easily but cuts out when engaging tines - 3.75 HP
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. If the carb. has a foat, then you can use the Den tek Brush on the jet as well. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Jun 13, 2009 | Troy-Bilt Garden
Troy bilt tiller
either the carb needs cleaned or theres a vacuum leak
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
