Computers & Internet Logo
Anonymous Posted on Sep 27, 2009
I have a blank DVD in the drive, movies loaded to
While using Sonic's MyDVD 6.2.0 I have loaded three home movies for burning, inserted a blank DVD into the DVD R/W drive but the burn button stays grayed out.
Anonymous
Level 2:
  • Expert 178 Answers
  • Posted on Sep 28, 2009
Anonymous
Expert
Level 2:
Answers
178
Questions
0
Helped
32865
Points
358
Burn your dvd with nero burning rom... it is a great software...
Testimonial: "Assumes that Nero will recognize the drive. It's worth a try, thanks."
Nanny
Level 3:
Genius:
  • Computers & ... Master 2,351 Answers
  • Posted on Jul 12, 2019
Nanny
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989308
Points
7262
If you want to burn a DVD on your computer, make sure that your computer has a DVD writer connected. Then you also need a DVD burning program to do this instead of just putting the data into the blank DVD. You may need to download a DVD burning program on your computer to burn the DVD discs. You could try Leawo DVD Creator which can support a lot of input formats and operate steadily.
How do i get movie files on my pc and burn it to a blank disc
insert a blank CD on your PC, then right click on the movie file and click on send to- CD/DVD drive
then follow the screen by clicking on next until you get finish.
tip
How to copy DVD Movie on Mac OS X?
This step-by-step guide is dedicating to demonstrate how to backup DVD movie (copyright protected included) to computer and copy DVD to a new DVD disc with no protections on Mac OS X (leopard included)
The tool you need is Aimersoft DVD Copy for Mac, which you can download for free from here.
It’s very easy to use, just with three simple steps then you can easily copy DVD on Mac.
Step1. Select DVD Source
After you install and lunch Aimersoft DVD Copy for Mac, put the DVD disc into your DVD drive. Click the “Select Source” drop-down list to browse your computer and located your source DVD movie (either in a folder or from your DVD-ROM).
Step2: Select DVD Copy Method
Aimersoft DVD Copy for Mac allows you to back up DVD to a folder on your hard drive or directly copy DVD to a new DVD disc. In the “Select DVD Copy Method” field, select a method to output the selected DVD movie according to your need:
If you want to back up your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly copy your DVD movie to a new DVD disc, you can just select the DVD Burner where you have inserted a blank DVD disc.
Note: If you are copying a DVD disc from your DVD Burner to a new DVD disc, Aimersoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
But if you have two or multiple DVD Burner, you just need to change object DVD to another DVD burner and insert a blank disc into it , then Aimersoft DVD Copy for Mac will automatically copy DVD movie to the new DVD disc. No need to wait for the conversion to insert a new blank DVD disc.
Step3: Program Settings (optional)
Set Buffer Directory: Specify a directory on your hard drive as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard drive that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step4: Start Copying DVD
After all things done, click the Start button to start copying your DVD movie or burning it to a new DVD disc. That’s all.
on Feb 10, 2010 • Computers & Internet
1helpful
2answers
Windows movie maker will not burn to DVD. Says to
As you may be aware, Movie Maker doesn't natively burn DVDs. Or Video CDs (VCDs), which are playable by any DVD Players, but are of significantly lower quality than DVD.
What do you need to into DVD? How about MyDVD is the easiest and direct route, requiring little or no format conversion.
Open this browser to see more about this program.
www.yboyandrei.com/mydvd
Hope this might help you a lot.
Please rate me, Thank You.
1helpful
2answers
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Dvd created inn sonic mydvd will only play once
It most likely has something to do with the way set top players store certain things in memory. have you ever noticed that if you pop a dvd out while watching then put it right back it, that it will resume? try putting another dvd in then putting the picture dvd in and see what happens.
I need driver for vdr m50
DE ESTA PAGINA DE ABAJO SE TIENE EL SOFTWARE DE LA VDR-M50 Y EL DRIVER USB.
http://www.camcorderinfo.com/bbs/t117442.html
#4 08-03-2005, 09:17 AM
ceide2000
New Member Join Date: Jun 2005
Other Software
DVD-RAM Drivers
http://www.fluidnetworks.net/DVD-RAM_driver.zip
*You can use this to format DVD-RAM disks. Personally I would use the function on the camera
Panasonic ISO
http://www.fluidnetworks.net/VDR-M50_iso.zip
*The whole CD image for you to burn your own copy. Includes Sonic MyDVD & DVD-Movie Album
Sincerely,
Chris Eide
2answers
DVD drive errors when trying to burn a DVD
try to use another burning software....ie... Nero.
2answers
Burning video to DVD
hi there
have you tried using another software? software that stops or cancels within you trying to use it only indicates that there might be conflicts with other softwares installed on your computer.
i suggest you try installing another dvd burning software.
hope this helps.
Grand Canyon Tech
Grand Canyon Tech
