Question about Panasonic Lumix DMC-LC33 Digital Camera
If i turn my camera on it says ''system error''.
I'v tried many things like forcing the lense to open, it worked, but i think it is getting to old for that...i've tried opening the lense then taking out the batteries for 24 hours, it didn't work...please help me with my problem!
    President:
  • 2,761 Answers
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
System error appears over my pics when in viewing mode and camera shuts
Turn the camera off, remove and reinsert the batteries, or unplug and reconnect the AC adapter.
Also, what is the capacity of the memory card you are using? If its 4gb, you will have an issue with the system error.
How long have you had this camera by the way?
Jun 10, 2010 | Konica Minolta DiMAGE Z5 Digital Camera
System error
This eroor usually comes due to faulty sliding mechanism.Put a bit of force on the focussing lense to push it back into camera casing. That's the reason the sliding mechanism won't work. The lense is stuck and if you force it back in, the sliding mechanism will work again. Not responsible if your camera screws up, so try at your own risk.
Or else try out this method
Pull the lens fully out and then it will work.It will be bit tricky to get the lens out. Use your nail to "grab" between the outer glass and the little plastic cover.
Hope this will work for others too.
Aug 28, 2009 | Konica Minolta DiMAGE G400 Digital Camera
My camera is Canon PowerShot SD870 IS. after i turned it on and the lenses goes outward as it should be but remained there even if i turned of the the power. i should mention it used to work properly.
That is lense trauma. I can be caused by dirt or lense being hit or zolted while open. Canons are strong cameras but if it make a grinding noise when the lense is trying to go back into the camera it most likely needs repair. try blowing the lens out with a hurricane blower or forced air. If the lense is tilted to one side even slightly no amount of forced air will help. good luck!
Oct 24, 2008 | Cameras
When i turn on my camera it says Turn the power off and on again
Hey, my camera the dsc- w80 did the same thing. When I turned it on, the lens opened 3-4 times and then it said "turn the power off and on again".
When the lens opened an closed, I pulled on it with my fingers and twisted it. I kept doing that: Turned the camera on and off, kept pulling and twisting the lens and now my camera works again!
May 15, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Lense error restart camera
A digital camera's lens is a very easy thing to have damaged. If the lens is bent some time you can force it in to the other direction and it will pop back into place. some times the gears get stripped and the lens then has to be replaced. I replace lenses all the time because of this issue. Hope this helps.
Apr 03, 2008 | Canon PowerShot A530 Digital Camera
Casio Digital Camera ex-s770 will not open
Hi, this is a problem alot of people get having with this type of camera.
It could be one of a couple of things first check the battery is fully charges as a faulty battery would cause this problem, do you have a switch on the camera that lets you see the pictures stored on it without opening the lense, not all makes and models do this some have switch you can slide and some is just push button the push button you cant do this.
So if yours is the push button one then the only thing to try if the battery isnt the problem is looking and removing anything thats caught in the side of lense.
Ok try removing battery and any mem cards if you have any in it then bang the camera firmly into the palm of your hand sort of shocking the camera to dislodge any thing thats stuck in the side of lense do this few times then replace battery and switch on usually this solves the problem.
If not then when you switch camera on grab the lense and help it come out taking it past where it gets stuck be gentle try this few times and see if camera comes on.
Once the lense is passed certain point the camera should come on.
So give that a try it does sound like something is jamming the lense so try pulling it out gently only do it when its supposed to be coming out when it trys to go back in let go again try this few times.
Failing this then the problem could be that either the camera has been put down with the lense open and forced the lense motor damaging it or the other thing that people tend to do is switch camera on acidently whilst its in pocket or case so that it switches on but the lense is blocked from coming out this causing damage to lense motor.
If the problem is in fact the lense motor then their is no way of getting this repaired they just dont repair these and you cant get the parts like lense motor no camera shop will even look at them as you cant get parts and also price of repair would cost more than replacing the camera.
Also check to see if your lense turns round as its coming in or out if it does this then try turning the lense as its coming out.
Let me know how you get on ok and ill try assist you further
Feb 22, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Problem
try two things re formatting the memory card in your pc if this fails switch on camera take the end of the lense and gently twist and pull the lense you may here it click be gentle do not force it then switch off and on again this may solve your problem
Nov 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Error message 5e02
Turn on your camera, when the lense is opened, hold it till the blue screen appears, extend the lense to his maximum forcing it a little bit then when you turn off your camera, the noise won't be here. Turn on again your camera and hopes it works. I tried it on my camera, works well at the first try then again the error, i did it twice holding the lense when you turn it on, then it worked perfectly.
Hope it works for you.
P.S : my english isn't well but i hope it helps.
Oct 17, 2007 | Olympus Stylus 710 Digital Camera
Minolta G500
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-(
Aug 24, 2007 | Konica Minolta DiMAGE G500 Digital Camera
Panasonic Lumix DMC-LC33 Digital Camera Logo
355 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
