Question about Toshiba Satellite M35X-S161 Notebook
Internet speed can I get wireless on this laptop faster than 54mbps
    Novelist:
  • 188 Answers
Toshibas seem to only like to have toshiba specific wireless cards in them. I would just buy a PCMCIA 802.11n adapter and plug it in the side.
Keep in mind you are limited in speed by the access point you connect to.
Posted on Dec 17, 2007
Advent 9315 wifi
How are you connecting to the internet?
1. Wireless
2. Wired
This can have an effect on the speed. A wired connection is not subsceptable to any interference and wont slow down from it.
A wireless connection can be slow because of the router, other things that broadcast radio signals, other things that broadcast non radio signals (like flourescent lights.)
How are you testing the speed? Unless you go to a website that has a speed test program or you are running a speed test application, there is no way to know for certain that your speed is what you believe it is. Your speed can also change due to the amount of people on the internet and other things like equipment failure outside your house.
Mar 31, 2014 | Zyxel Computers & Internet
Netgear N300 is slowing down my internet connection
The router limits the data speed to the wireless reception.
802.11 G speed (maximum) is 54Mbps.
Jul 17, 2013 | NetGear N300 Wireless Router
I am running hughes net satelite internet on a hughes HN 9000 modem and trying to setup and configure my linksys E3000 wireless router for two hp laptops on direct ethernet connection to our desktop,...
Are you trying to connect the laptops via wireless? Is that where you are seeing 75 mbps? I am assuming you are, and 75 mbps is really not how fast your internet connection is. Rather, that is how fast you are transferring data from your laptop to the wireless router and back. Generally speaking, this should be a way faster connection than your internet is running at. Chances are your internet connection speed is 10 to 20 mbps, which is good and fast.
It is easy to get the two confused, but basically a wireless connection of 75 mbps is an uber fast connection to your wireless router, and only if your actual internet connection was faster than that 75 mbps would you see any slowness due to that.
Wireless N routers are capable of delivering up to 100 mbps connection speeds, but again that is only from your device to the router. The router then goes to your modem and out through the internet. Chances are that connection is not 100 mbps because of interference, which can be walls, other wireless devices, etc.
One way to test your actual internet connection speed is to go to www.speedtest.net and click on one of the links on the map. This will tell you how many mbps you get to the internet.
Mar 17, 2011 | Linksys E3000 Wireless Router
My network card is only allowing 54mbps , I have 1.5gig dsl with a 300mbps router Do i need a new network card the driver is updated to last update
Your wireless network card is more than sufficient to handle the bandwidth provided by your DSL connection. A "1.5" DSL connection refers to a 1.5Mbps DSL line. Your network card is an 802.11G network card. Simply put, your network card will only run at a maximum of 54Mbps, far short of your 802.11N router's maximum speed, but provides more than enough room for the bandwidth provided by your Internet Service Provider. Gigabit connections (connections with speeds measured in 'Gbps') are almost exclusively for private networks or corporate networks with Fiber Optic connections.
In layman's terms, you can get a newer network card for your computer that will improve the speeds between your laptop and any other computers on your network, but as long as your network card is supported by any modern operating system, odds are it is able to transfer data fast enough to keep up with your DSL connection
Nov 25, 2010 | Toshiba PA3235U-3BTM Network Adapter
TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC): signal strength 85% green but tx rate 11 instead o...
Im sorry but you will never get 54 on your card toughs are theoretical maximum speeds and I have never seen a system actually achieve them the actual speeds received by wireless devices are actually much lower and 11 is a normal speed wile running over wireless. Im sure this isnt what you wanted to here and I am sorry but it pretty much comes down to manufactures lieing by telling you it goes to speeds that can never be reached.
I hope this helped.
Thank you,
Norse
May 16, 2010 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
100mbps on my house computer but only 54 on my laptop
100mbps is just the maximum speed capacity that can be used and depends on the speed that you subscribed so it doesn't mean you'll get a sharp 100 mbps on that.
Mar 31, 2010 | Toshiba Satellite M55-S331 Notebook
Ethernet works wirelss is very slow
Most of the wireless adapters connect at a speed of 54mbps max, while wired lan connection adaptors (LAN adapter/cable) works at max of 100/1000mbps. hence use a cable to connect the PC to make it faster than using wireless.
Aug 17, 2009 | 2wire 1800HG Router (RG1800HG00)
Simple broadband question plzzzzz awnser
lol the cost of your internet will only change if you call them up and change your plan. if you go out and buy a new modem it will go the speed of the modem....so basically having a broadband connection with a 1mbps modem is like trying to force an elephant through a mouse hole....lol so to answer your question straight you get a new modem you'll get faster internet....have fun
Feb 06, 2009 | Monster Cable (109611)
Wireless connection is slower than wired!
Yes there is a difference although most router manufacturers claim that you can get 4 or even 6x times faster than 54Mbps of a regular 802.11g wireless standard, wired connection(10/100/1000Mbps) are still faster because they are less subjected to interference unlike wireless that are vulnerable to interference like cordless phones, microwave devices, lighting fixtures, distance and the obstruction between your wireless router and the computer.
Nov 06, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Toshiba Satellite M35X-S161 Notebook Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
