Question about Vehicle Parts & Accessories
Hi can anyone guide me to install a remote spy alarm on a holden commodore vx 2002?(chevy) thanks
    President:
  • 2,004 Answers
I will email it to you. Reach me on onifadeadewunmihotmail.com
Accept this first.
Posted on Sep 27, 2009
What each colourvwiringis for in vx ,2002,Commodore
The Holden Commodore (VX) is an executive car that was produced by the Australian manufacturer Holden from 2000 to 2002. It was the second iteration of the third generation of this Australian made model. Its range included the luxury variants, Holden Berlina (VX) and Holden Calais (VX), and it formed the basis for a new generation Holden Ute (VU) coup? utility and Holden Monaro (V2) coup?.
The VX series was produced between October 2000 and September 2002, as a minor restyling update to the VT series from 1997. It introduced greater model differentiation along with gains in crash safety. An intermediate Series II was launched in August 2001, featuring a revised suspension system among other changes.
Thanks,
Landon
Apr 16, 2017 | Cars & Trucks
Wat kind of v8 is suitable for a 1997 3.8 v6 holden commodore excutive
your VT /VX came out with a V8 engine
you need the engines ECU and the V8 gearbox
manual diff ratios can be optional
1997 -2002 engines will bolt in
you could go up the next commy V8 model it has roller rockers
you can have a v6 or v8 supercharged if you like
once all bolted in you need a mutt 2 diagnostic reader to reset all the keys and modules and immobilizer for it to start and run
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002
Oct 19, 2016 | Holden Cars & Trucks
My battery went flat and I jump started my car (Holden VT) now my stereo is locked. Dose anybody know how to unlock it. It's a eurovox radio unit.
Samantha, You need the VIN and the radio serial number. Take those into a Holden dealer to get the radio code and programming instructions from the dealer. They may want a small fee for the #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/131983-vt-stock-radio-cassette-player-security-code.html
Radio Security code Street Commodores Online Forum
Go Technologies Eurovox FAQs
Aug 26, 2016 | Holden Cars & Trucks
Will ls1 go in vx commodore s 2000
yes VX V8s were fitted
depends on what state you live in
LS1 fitted may need a modification plate
needs the LS1 engine ecu and
and a few extra wiring and
join the just commodore forum for loads of helpful information
Jul 29, 2016 | Cars & Trucks
2002 VX Commodore. How can I remove thermo fan?
Holden
for the easy solution download the pdf file
Apr 05, 2016 | Holden Cars & Trucks
Holden Commodore vx 3.8 v6 turn signals don't turn off
check your wires that wounded it may cause trouble.
Mar 03, 2013 | Cars & Trucks
Reprogram remote key vx commocore
mr minit! locksmith! what area do you live in? most small workshops have a scan tool that will program commodore keys from vn to vy. hope this helps
Aug 04, 2009 | 2004 Isuzu Rodeo
Holden vx commodore immobiliser
to fix the key you need a screw driver to pry the to halves of the key casing apart (make sure you have a spare set) taking care not to damage the internal electronic component board, because this electronic circuit board (cct bd) is powered by a 3 volt battery (which is also used to run the bios on computers) can be purchased for about 3 dollars from **** smiths, you need a small pair of side cutters to cut the metal tag connections between the battery and the cct bd taking care to note which is the positive and negative tracks on the cct bd, then using a soldering iron desolder the metal tag connections from the cct bd take care not to damage the copper tracks on the cct bd, try to use the proper desoldering technique (the copper gauze or a suction gun) to remove excess solder from the metal tags because they need to be removed, when the tags are removed from the cct bd there is a small hole on each copper track for the positive and negative reconnections to the newly purchased battery, use light audio speaker wire, black for negative and red for positive, presolder the wire ends first then cut the bear ends down and solder to the tracks taking care not to cross tracks with the solder, then shorten the both positive and negative lengths so the battery and the wires will fit back into the casing of the key and resolder the wire connections to the battery, before closing the key casing test the key to see if the immobiliser is operating then relocate the ring seal and close the two casing together with tape or reglue with arildite glue. if your soldering technique is not up to scratch practice your technique until you feel confident and this should save you about $100
Aug 02, 2008 | Graco Spree 511 Holden Travel System...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
