Question about Onkyo TX-SR606 Receiver
Onkyo 606 Video Drop out
My Onkyo 606 has been fine for a year but now whenever I pass 1080p content through it, whether it be via my PS3 or HTPC the video drops out for a few seconds every few minutes, it's really annoying!
I have tried different cables with no difference. I have also confirmed that it isn't the PS3 or HTPC because they run fine if I connect them directly to the TV. It is also only with 1080p content because I never get the problem when I'm watching sky, which is 1080i or when I actually start a 720p game on the PS3
  • Onkyo Master
  • 4,006 Answers
Main board fault, its input feed on the board might be failing, it could also be a failing capacitor, you would need to open it up to have a look and see if there are any capacitors failing.
Posted on May 14, 2017
3 Suggested Answers
  • 14 Answers
SOURCE: i need onkyo
Scientific Atlanta
00000, 00008,
00237, 00277,
00877, 01877
Posted on Mar 03, 2009
smarthome2
  • 1114 Answers
SOURCE: 1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
Posted on May 23, 2009
I cannot get video signal from my Samsung p1590 Blu Ray player via HDMI to pass through my Onkyo TX-SR606 AV Receiver. I get video if I connect Blu Ray player directly to TV, and have tried all HDMI ports...
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Onkyo TX-SR606 Receiver
Onkyo 606 connected to tv with video only via hdmi/dvi cable. Receiver/tv must be turn on/off several times for video to get to tv. I know it is receivers fault because tv will say no video signal. After...
I am having this exact same issue with this receiver. I have to turn it off several times in order for it to pass through... Any chance you figured out how to fix this....
Oct 15, 2009 | Onkyo Audio Players & Recorders
Onkyo tx-sr 606 HDMI signals not working anymore...
I am sorry about your issue,. If the reset did not resolve your issue the receiver would need to be serviced. It if was purchased from an authorized seller less than 2 years ago it would be under warranty. Thank you. Onkyo USA
Mar 09, 2017 | Onkyo TX-SR606 Receiver
Onkyo 606 doesnt show video anymore fom ps3 over hdmi
i hate to say it i got the same problem and the only way i sorted was a master reset which means u have to do all the set up again and asign all the hdmi again but since i done that no problems to do this un plug the lot for an hour reconnect everything then push and hold the vcr button and push stand by a message will say clear on the receiver then it is back to when u frist got it out th box hope this helps
Sep 03, 2009 | Onkyo TX-SR606 Receiver
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Upscale from 480p Signal via HDMI
ok the problem might not be with your receiver it is with your direct tv settings. Double check to make sure you go to the format and set it up to be fixed or 1080i whichever will give you the highest resolution. Check your manual for the direct tv receiver. If this is all correct for the DTV then you must go into the setup on the receiver and at hardware icon toward bottom check on that box, now goto the hdmi settings and make sure it is set to through. this will allow the best picture with no upscaling which will degregade picture for blu ray. so your direct tv will be only 1080i but very impressive. if you still want to upscale you can then you have to change the hdmi settings from before to upscale 1080p . I just hope that your dtv can output 1080i it will give a better picture than 480p even if both are upscaled to 1080p
Oh i forgot to ask if you are connected through hdmi to the tv. Hdmi is the only option for upscaling
Feb 21, 2009 | Onkyo TX-SR606 Receiver
Ps3 and onkyo receiver
Hello.
I have a similar setup and am having problems of my own, but i've got it somewhat working at the moment.
I have the TV connected via HDMI to the receivers HDMI output port.
I have the PS3 connected via HDMI to the receivers HDMI input port 1.
I went on the receiver and followed the instructions in the manual to setup the DVD function on the receiver (i chose to call my ps3 a dvd) to use HDMI-1. I can't remember the button combination as i'm not at my hosue right now, but it was in the HDMI section of the manual (page 44 on my manual). Essentially I had to tell the receiver to enable HDMI for the DVD function rather than being defaulted to "No". At that point, with the default ps3 setup, I was able to get video to pass through.
Next, i went into the video options on the ps3 and changed it to 1080p (since my tv supports that).
Where I"m having my problem is that the sound from the ps3 outputs directly to the TV and doesn't output on my receiver for some reason.
How I've rigged that to work is to take the HDMI to RCA cable that came with my PS3 and i plugged in the Red and White wires on the back of the receiver in the DVD section of inputs. At that point the sound comes through the receiver.
What I don't know how to do and would really like to know is how to get the sound to output on my receiver via HDMI only and not with the extra cable.
Anyway, if i'm making sense above and you follow that, you should be up and running (but maybe not in an optimal configuration).
Let me know if you ahve any questions.
Also, if anyone knows the solution to my issue, i'm all ears.
Thanks.
Nov 09, 2008 | Onkyo TX-SR803 Receiver
My PS3 is hooked up via HDMI cables to my Onkyo TX-SR 605, then to my 1080p LCD via HDMI. When playing BD movies the TruHD or DTS-HDMA lights don't come on. It is just stuck on Multi channel,Direct or...
YOUR PS3 DOES NOT OUT PUT TRUHD OR DTS HDMA AS STANDARD,YOU CAN GET A UPGRADE ON THE WEB FOR DTS HDMA BUT NOT FOR TRUHD.FOR BETTER SOUND AND PICTURE SELL PS3 AND BUY PANASONIC BD30.
CABLE GUY.
Jun 26, 2008 | Onkyo Audio Players & Recorders
Ps3 defaults to 576p when connected through onkyo 606 receiver
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Jun 22, 2008 | Audio Players & Recorders
Onkyo TX-SR606 Receiver Logo
272 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
