My Tungsten E2 is not charging. It has been with me for almost 4 years now. What seems to be the problem? This is not the first time though I encountered the same problem. 3 years ago I encountered the same problem. I didn't do anything nor replace the battery. After a couple of months it charged. However, the case is different now. Been trying to charge many times but still it didn't work.
I had symptoms with my Tungsten E2 where the charging icon would show up when the charger was connected, however, it didn't seem to charge, because when it was removed from the charger hours later, it would still show the same percentage of charge (as read by touching the battery icon while in the favorites screen).
Tried resetting the unit, reconnecting multiple times, different charge cables, and it was always the same.
I thought it might be time for a new battery, so to check it out, I got my T-5 Torx driver, removed the four case screws, and carefully pried open the case from the top (the bottom has hooks that have to be disengaged by sliding the case half downwards after they're separated from the top)
Measured the battery and it seemed to be okay, and after unplugging the battery connector and reconnecting it, it worked normally again. Charged quickly back up to 100%, and the battery is fine.
It looks like something may get out of sync with the battery charge circuit, and by simply unplugging the battery to allow it to reset, it restored operation, no replacement battery needed.
i can't access my list of pdf files. I need to delete some files but the application jumps from the...
(More)
i can't access my list of pdf files. I need to delete some files but the application jumps from the most recent pdf file I opened to the main menu
I cannot get my hotsynnc to connect to the internet. I have a palmone tungstenE2. I replaced the...
(More)
I cannot get my hotsynnc to connect to the internet. I have a palmone tungstenE2. I replaced the cable and reinstalled the software. Still will not talk to my computer. it keeps telling me to check my setup.
Palm Tungsten E2 will not turn on. I charged the battery and I pushed the reset button on the back....
(More)
Palm Tungsten E2 will not turn on. I charged the battery and I pushed the reset button on the back. I know the charger works because I checked it out with someone elses Palm.
So I have a nokia and whenever I turn it off and turn it back on it always takes forever to load up...
(More)
So I have a nokia and whenever I turn it off and turn it back on it always takes forever to load up the screen and my messages and phonebook I just want to know how to fix this problem it's really annoying please help.
